Question about Dell Dimension 4550 PC Desktop
Cannot open CD drive on startup to reinstall XP?
Computer has been wiped clean by brother. CD drive not in Bios boot list and won't open on startup. How can I reinstall anything???
  • 1,602 Answers
LOOK FOR A PIN HOLE LOCATED ON THE CD-ROM THIS WILL MAKE THE CD-ROM TO OPEN.
OR
SOME KEYBOARD HAVE THE OPTION ON THE KEYBOARD TRY PUSHING IT A FEW TIMES AND WAIT FOR 1 MINUTE AND THEN PUSH THE REFRESH BUTTON ON THE KEYBOARD OR IN THE PULL DOWN MENU ON THE DEST TOP IN VIEW AND HALF WAY DOWN.
LAST OPTION REMOVE THE POWER FROM THE DRIVE WAIT 2 MINUTER THAN PLUG PWR IN TRY OPEN BUTTON AGAIN.
LAST YOU CAN FORCE THE CD-ROM OPEN WITHOUT BRAKING IT CAREFULLY.
ONE OF MAY BOOK SAY TO CALL THE VENDER OF THAT DRIVE AND SEE IF THEY HAVE ANY IDEAS ON HOW TO OPEN THE DRIVE WITHOUT BRAKING IT.
LAST BUT LEAST IS THE DRIVERS MAYBE CORUPTED AND YOU NEED TO DELETE AND REINSTALL AS NEW HARDWARE AND USE THE CONTROLL PANAL OPTION TO IN STALL NEW HARDWARE OR HARDWARE WIZARD.
ROD
Posted on Feb 17, 2009
  • 51 Answers
Open up your computer case and make sure that the cables leading into the cd drive are securely attached at both ends. there should be 1 power cable and 1 ribbon cable attached to the cd drive. if these are fine then open up the drive manually using a paper clip into the tiny hole on the front of the drive.
Hai sir i want to reinstall win xp in asus k8v-mx sata hdd system but it cant found the cd drive what i do?
For checking:
1.cd rom/dvd rom is functinal/ working properly
2. sata cable is ok.
3. cd window xp is clean and clear.
if all that okay, try again reinstall.
if 1 and 2 is okay, you should see the cd rom in [my computer]
so, what you need now is try to clean your cd/disk with suitable cleaner. if you dont have it, you can try with perfume with have alcoholic. clean using soft tissue and make sure no dirt at that disc.
You say, you cant found cd drive?
in [my computer] or during setup?
if your pc still can log on. try log on window, open my computer to see and check your cd drive have no problem.
try ..and request again. im here until 5 pm..hope can help you
May 14, 2011 | ASUS K8V-MX Motherboard
Box have no problem i can,t connect to computer
software problem thn press F8 AT STARTUP & go in safe mode or repair XP
Else hardware problem thn clean sliver portion of ram by rubber
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 02, 2011 | Computers & Internet
How to reinstall windows XP
If your computer boots up you should be able to reinstall with your xp os disk, click on your cd drive & choose reinstall or new install, after that you'll probably have to go to windows update & update the system, if that does'nt work you may have to go to bios settings & set the cd rom as your boot devise, restart & install that way, after your done be sure to set the bios to thier default settings.
Dec 07, 2010 | Computers & Internet
Had to wipe my acer aspire 5315-2077, only thing I did not erease was my bios setting . I need a startup disk or boot disk or can I use my old xp cd or me. cd.
Yes but not ME cd. You can use your old XP cd as a boot disk, ensure that you have set the boot order to CD drive for the first boot, and upon restarting make sure the XP cd is in the CD drive.
Apr 24, 2010 | Acer Aspire 5315 Notebook
I took my friend to wally world today and he bought a new Emachine got it home and hooked it all up... and all it says is choose a boot drive. Brand spanking new lol. Called them and in very very broken...
If it gives you options to choose from such as Windows XP, NT 2000, etc. then select one and press enter. If not, try reinstalling Windows using the restore disc that came with the computer. Make sure to set your CD drive to boot first from your BIOS setup. To enter the BIOS press F2 at startup. Then select the CD drive and set it to first in the Boot Order list. Restart your computer with the Windows disc in the CD drive and follow the on screen instructions.
Hope this helps, good luck. Don't forget to vote. Thanks :)
Feb 24, 2010 | E-Machines eMachines Desktop PC
My computer starts to boot but never makes it to the welcome screen. It stops at a blue screen. how do I access the recovery partition ?
Push Alt F10 or F10 (depending on laptop brand).
To fix this you need a Recovery CD(should be with your computer) or the Windows DVD itself to launch Repair Service.
Jan 12, 2010 | Sony VAIO VGN-N130G/W Notebook
My matser hd oin is aet to master. My slave is set
If you have the XP install disc just disconnect your master HD and use XP disc to format the slave drive. Exit after format, remove XP disc and reconnect Master. You now only have 1 drive with an OS.
Oct 05, 2009 | Symantec Norton Partition Magic-8.0...
How to install windows
You need the windows CD to install windows, insert the cd in drive and press enter when asked to press anykey to start from cd.
if you don't get the start from cd and the windows setup doesn't start then most likely your computer is not set to startup from a cd drive, look in the cornerts of your computer screen look for boot menu or press this to enter setup / bios
you can either use the setup / bios or the boot menu and boot from the cd.
if you use the boot menu, make sure the cd is in the drive and select the drive from the list
if you don't find boot menu or it doens't work go into the bios / setup and you will need to change the boot order to include the CD drive FIRST before hdd or floppy. consult your motherboard manual or ask me if you need help in the bios.
Dec 01, 2008 | Microsoft Windows XP Professional With...
Erase a hard drive
IF you have the XP installation CD you can easily do that, Just set your BIOS to boot from the CDrom then put the XP CD on your CD drive then restart the computer , so your computer will automatically boot from the XP installation CD then on that process you will have an option to format the entire hard drive that you have using the XP CD installation, then just let the installation finish...
Oct 16, 2008 | Computers & Internet
Computer boot up
just worth a try if your using XP. :) using XP recovery console:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type the command:
chkdsk  /r
6.    When finished checking, exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Also verify that your HD has been set to master in Primary IDE and the others (if you have like CDROMS) in as slave.
Oct 28, 2007 | Microsoft Windows XP Professional for PC
Dell Dimension 4550 PC Desktop Logo
Alun Cox
