Question about Epson Stylus Pro 7800 InkJet Printer
Epson 7800 printhead faulty
I pulchaced an Epson 7800 printer 2 years ago. It has been an excllent printer and was not over used.. I was having print colour problems, so I called a reputable company to come and repair it . I was told today that the print head is broken.. and it will cost €600 to relace and fit part ... Are ther any cheaper alternatives available to me or is this part covered under guarantee.
Regards Mark (Irelandl)
    Top Expert:
  • Epson Master
  • 12,962 Answers
Not covered. A new printer is far cheaper.
Posted on Jul 20, 2017
SOURCE: Epson cx11nf printing problem
on the right hand side of the printer towards the back, but on the right hand portion of the printer there is a tab you can open it is about 3/4 inch wide and 2 inches long. After you pop the tab off, there is a handle. Pull the handle out SLOWLY all the way. This will wipe off the printing head like a windshield wiper. Insert the handle back in slowly, and whallah!!!
Fixed me real good!!!
Posted on Jul 25, 2008
SOURCE: Using colour ink without black ink in Epson CX5500
good
Posted on Nov 20, 2008
aicaxz
  • 511 Answers
SOURCE: Hi my epson r285 with ciss is leaving ink blotches
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Posted on Jun 21, 2009
  • 16 Answers
SOURCE: Epson Stylus Pro 9600 horizontal banding problem
Also try running at slower print speeds
Posted on Jul 12, 2009
cns assoc
  • 677 Answers
SOURCE: My printer will not recognise non epson cartridges
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!! How you were able to use generic is amazing. I was not able to do that!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
TRYING PURCHASING GENUINE, and see what happens? This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 31, 2010
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
Epson 7800 full waste tank
Go on YouTube. You will find instructions for cleaning an Epson waste tank there
Jul 04, 2010 | Epson Stylus Pro 7800 InkJet Printer
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
7800 epson not printing right
yur black ink has dried compltly.... i think yu have 3 blac catridges.. replace 1 of it.. i meant refill it.! it will work!
Jul 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Change print head for Epson 7800
Probabily not worth the effort, Epson printers are really cheap to buy. Check their website in the Clearance section.
Jun 29, 2009 | Epson Stylus Pro 7800 InkJet Printer
Printing very faded
if you have not used the printer for over a year, the ink in the printhead must have dried blocking the nozzles. you can remove it and dip in a little warm water to dissolve the dried ink, if this doen't solve the problem, you will have to replace the printhead
May 19, 2009 | Epson Stylus Photo R1800 InkJet Printer
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Printer wont work just feeds paper straight through
First try reinstalling driver software on your computer.
Either use printer CD or download from website:
Epson Driver Download
Epson America, Inc. - Support
If problem persists after downloading software, then that means that ink had clogged the printheads after drying up on old installed cartridges.
In that case either order a new printhead from Epson, or replace the printer.
Feb 03, 2009 | Epson Stylus C46 InkJet Printer
Cleaning or replacing printhead / hose
Buy them at a official EPSON service center or throw away the printer and buy a HP.
Actual EPSON printers uses 5 ml ink cartridges for each color and black. HP printers has the same volume cartridges but there are only 2, tricolor and black.
If a HP printing head becomes clogged (don't worry, it almost never happens), just throw away the cartridge and install another (the print head comes with the ink cartridge). If a EPSON print head becomes clogged you have no other choice than buying another printer because EPSON's print heads are expensive and become discontinued 12 months after the printer model was launched to the market.
Also, HP Printers are cheaper than those from EPSON and offers excellent print quality on any paper. Compare a 10 years old HP printer with actual EPSON's and the HP has the sharpest black printing. The color is another story.
Mar 13, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Poor printing quality with my Epson stylus C 66
If it sat for a long time, then  some of the nozzels are probably clogged.  Running the clean feature helps, but it probably won't work a hundred percent.  The best way is to disassemble the whole thing, take the printhead out, and clean the nozzels with a sopping wet cloth.  That takes some doing, and there's no manual to tell you how...you just gotta tinker till you can get it apart.
If that still doesn't help, it's probably shot.
Oct 29, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus Pro 7800 InkJet Printer Logo
421 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
