Question about Canon PIXMA MP530 All-In-One InkJet Printer
Check printer 5100 code in window
Printer ink wont move
    Sergeant:
    Champion:
  • 373 Answers
This is just a try and error thing ok
Unplug it from the computer and then unplug it from the power
and plug it back in again
Posted on Feb 17, 2009
My cannon mx300 is giving me an alarm code 5100
5100 means either the carriage is not moving freely back and forth or there is grease or ink on the encoder strip. You can clean that clear plastic strip behind the carriage with a Q-tip, but also check on the right and left side for paper scraps stopping the carriage.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Selphy DS810 printer. Error code 5100. Possible full waste ink absorber? I just replaced an empty ink tank. Can I fix this problem myself?
How long have you owned the unit? This problem occurred after you changed the ink tank? Once I have more information I can assist you further.
Thanks,
Lee
Oct 16, 2008 | Canon Office Equipment & Supplies
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Wont print
Have you reset the ink cartrige?  Have you unplugged it and replugged it? Are there any flashing lights on the printer? Did you recently add software or had a windows update? Unistall and reinstall the driver.
Dec 02, 2008 | Canon PIXMA MX310 All-In-One Printer
Printer is flashing checkprinter 5100
dear bria13,
Code 5100 indicates carriage operation error. The printer performs initialization process (include carriage unit operation) at first time we turn it on. During this process carriage unit will move right and left reading film timing **** strip. If carriage unit can read film timing **** strip successfully then it will move to home position (originally on purge unit part). Otherwise error code 5100 shows.
Here are possibilities and corrective actions:
  1. Film timing **** strip become mist caused by grease or ink; wipe film timing **** strip with moistened cloth.
  2. Carriage unit faulty;replace carriage unit.
Find more article about canon ink jet printer here and please give your rating
Regards,
Nov 09, 2008 | Office Equipment & Supplies
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error 5100
Have you taken the printer apart? as the issue I had with our spare printer was that the home mechanics around here had taken ours apart for some reason and had not put the paper roller pin back in correctly. it was sticking out preventing the ink tank holder from moving.
Dec 26, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Nov 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
I had the same problem too. Brand new unit and 5100 error comes on after power up. There is nothing jaming the ink cartiage, and it only moves a little bit to the left then jams back to the right. I can't even load in new ink cartiages. It's going back to the shop today.
Apr 23, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
