Question about Kenmore Elite 45986 Front Load Washer
GE Dishwasher won't fill (Tested valve and switches)
My GE GSD680XX02WW was making noises like it was washing with rocks. The last time I ran it, it started to smoke. When I checked it out, I saw that it was not filling. I tested the fill valve, float switch and door switch for resistance, and all checked OK. I even checked the solenoid on the drain valve, in case there was an interlock to the fill cycle (it was OK too). I am not getting any voltage to the fill valve during the fill cycle. Is this a bad timer? The motor is still running and what water is in the bottom is coming out the wash arms, so the motor is getting the "go" sign from the timer, just not the inlet valve.
Thanks in advance
  • cmgr Feb 17, 2009
    Thanks skrbin, I'll check that. I never thought that a high t-stat reading would shut down the water supply. interesting!
    Thanks again
  • 121 Answers
Check thermostat it maybe overheat and gives a false signal that water is warm,it is on bottom.
Posted on Feb 17, 2009
Completely disassembled + tested GE dishwasher, but still won't drain
Air Gap on the sink could be clogged.
Solenoid on the motor could be melted or overheated and it is not letting the check valve open.
Also the motor should make noise. It could be stuck so that it gets voltage but is not turning. You can hear it humming. Unplug the dishwasher and from the front underneath, you can see the fins of the motor. It should spin freely. If it is stuck, the you can force it free by turning the fins with a couple of screwdrivers.Sometime if you don't use the dishwasher weekly, the motor seals dry and gets stuck.
Mar 26, 2014 | GE Dishwashers
Won't Fill and will attempt to run wash cycle when turned off and door is closed
Hello ddux97 - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink).
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Check inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• If this is a new install, then make sure the unit is not pressed up against the cabinet and the fill tube is not squeezed closed.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Make sure the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some models of Frigidaire dishwashers use a water pressure switch that will shut off the water valve if the tub over fills. These models do not have floats.
I hope these troubleshooting tips help you in some small way.
Jun 20, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Not filling with water
Hello there and welcome to fixya
here's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® or a ge washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Please keep m,e posted on what you find so i can continue to help troubleshoot
and replace any parts that you may need ok
Best regards Michael
Feb 05, 2011 | GE Washing Machines
I have a du1030xtxs1 dishwasher that will not even start filling. The door latch switch, over fill switch and fill valve seem to be okay. I tested the wires coming to the fill valve by disconnecting them...
Yes, probably a control board, or wiring to the valve from the board. Call Whirlpool with your model and serial number, if the manufacturing date is within the last year, they will cover the repair without a date of purchase. Or you can contact the seller and see if they have a date of purchase for you. Good Luck, Appliance Specialists
Dec 16, 2010 | Whirlpool DU1030XTXS Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Washer won't fill with water
replace the water inlet solenoid valve
Jul 23, 2009 | GE Profile WPRE6100G Top Load Washer
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher pump caviation
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Dishwashers
Kenmore Elite 45986 Front Load Washer Logo
176 people viewed this question
Sal De
fordexpert
Robert Rankin
