Question about Brother DCP-7020 All-In-One Laser Printer
Brother HL-1850 Prints Too Light
Anyone else experience text darkness problems with this printer? It's otherwise a great printer with duplexing at a fantastic price, but: First one printed too light at other than the highest density settings. Brother support said they weren't getting other complaints like mine. Sent out a replacement toner/drum, but no change. I returned the printer and received a replacement. The replacement prints exactly the same way. I have to set HRC all the way to "dark" (does this actually DO anything???) and density all the way from the default "0" to "+6" in order to print text as dark as you'd expect from other laser printers. Of course, the problem with this is I'm using up toner much faster than I would ordinarily. prints too light
  • fuzz ball May 11, 2010
    not working
  • fire77 Sep 19, 2016
    Go to the default printer settings:
    Click START, click DEVICES AND PRINTERS, Right click on BROTHER HL-1850,
    Click PRINTER PROPERTIES,
    On the GENERAL Tab Click PREFERENCES
    One the LAYOUT Tab Click ADVANCED
    Under PRINTER FEATURES make sure these three settings are: TONER SAVE MODE: "OFF," HRC: "DARK," DENSITY ADJUSTMENT: "6"
    Click OK all the way out of the settings.
    Now go to print something and double check the default settings match what you changed them to. (might require a restart)
    I hope this helps you, if not, then you might require a new toner or, God forbid, a new drum. before replacing the toner though, try removing it, shaking it side to side, and replacing it to see if that helps.
Brother HL-4070CDW still prints page upside down in duplex.
Check the duplex settings, often you have a choice on long side or short side for duplexing. If short side is chosen then it will print duplex as though you are making a flip chart not a book
Nov 10, 2014 | Brother HL-4070CDW Printer
I want to print on both sides of the paper
The Brother HL-2040 machine does not have and cannot be fitted with a duplexer to print both sides of the page automatically. You can only duplex manually, that is - you turn the page over and put it back in the machine to print on the other side. Some settings will allow to print double sided manually, where the printer prints all the odd numbered pages then instructs the user to place ALL the printed stock back in the paper tray to then print all the even numbered pages.
Mar 09, 2014 | Brother HL-2040 Laser Printer
Still having black spots even after cleaning drum. Could anyone tell me how to fix that?
Hi Brian,
Go To Below official Brother Printer Page For Your problem, White spots on black text and graphics or black spots appear Brother Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Dec 04, 2013 | Brother HL-4150CDN Laser Color Printer,...
My brother hl 1440 laser printer prints out grey on my documents. i think its the drum ?
well if it started and got worse over time it could be the drum otherwise it may be the driver that is running the printer also there normaly is a light on the front that will light up red if the drum is shot
Apr 10, 2010 | Brother HL 1440 Laser Printer
I have an HL-4040CDN Brother printer that prints too red. We just purchased it and need how to fix this problem. It also prints colored text too light.
Many people are having problems with this machine. If you are dissatisfied with the quality I would return it and try something else. Your most economical solution is going to be a factory refurbished (with warranty) HP color laserjet. Staples usually has some good deals.
Jan 18, 2010 | Brother HL 1440 Laser Printer
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
How do you clean the drum?
Brother had me take a tissue and wipe the drum. You can spin it with the gear on the left had side of the drum. Then they had me slide the blue tab 30 times back and forth.
Also take a soft cloth and clean the lens on the inside of the printer. First take out the drum unit. The lens in toward the back.
Feb 27, 2008 | Brother HL 1850 Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
132 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
