Question about DISH Network IR Remote Control
My Dish Network Remote will not allow me to...
It wont allow me to turn my TV on/off or control the volume? Any Ideas on how to fix this?
  • 514 Answers
Go to page 19 of your manual (for the E-Z remote) or here "http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/EZ_Remote_Manual.pdf"
(if you don't have the manual)
or to here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" if you have a different remote.
basically, turn your TV on, then you press the antenna button for about 5 seconds until the TV button lights, then use the channel up/down buttons to find the code (the TV will turn off when you find it) hit the TV button again to turn it back on, then hit mute to set the code! good luck!
Posted on Feb 22, 2009
I got my dish network to turn off the tv and adjust volume but remote wont turn on the tv
Hi there!! This is Kimberly Escobar with DISH Network, just ran across your post and wanted to provide you with some helpful information to help get your problem resolved. If your remote control is functioning as far as turning the T.V off and the volume, one of the things you may want to check is that the power button is working, you can verify this by trying to turn on and off the receiver. If it works for the receiver you will need to try to address the remote to your T.V again using different codes. To address a remote to the T.V we use certain codes that integrate to the remote allowing it to function with the T.V. unfortunately we cannot promise the remote will function the T.V completely. You can find more codes at this link here http://www.dishnetwork.com/SupportSection/remote-setup. If you need any additional help please free to contact us directly at 1800-333-DISH. Hope this is helpful to you.
Feb 10, 2011 | DISH Network IR Remote Control
I can program my new TV to turn on and off but can't get the volume to work.
Hello there! This is Kimberly Escobar with DISH Network just ran across your post and would like to help you by providing you information that may help you get this issue resolved. Depending on the brand of television you have we have certain codes that integrate to the remote allowing it to work functions on the T.V. Unfortunately we cant promise that the remote will work all the functions on the T.V. You can find the different codes in our website at http://www.dishnetwork.com/SupportSection/remote-setup this should help you try different codes and find the one that might work power and volume. If you have any questions please let us know you can contact us directly at 1800-333-DISH.
Feb 09, 2011 | DISH Network IR Remote Control
Volume control on sanyo tv to dish controler
hy2277
I have provided a link on how to program the remote to your TV so you can control the volume and turn the TV off/on. I have also provided the codes available for your Sanyo TV. I hope this helps.
Instructions on programming the remote to TV:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network IR Remote Control
Get volume and on/off button to work on dish remote
Hello, you may have already gotten this resolved, but here are some simple steps to get this resolved. Just follow this link to our website, and you will be good to go real soon!!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 31, 2010 | DISH Network IR Remote Control
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
I would like to control my dish network receiver 3100 with my samsung remote
trifonas_ger
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
May 07, 2010 | DISH Network 32 Ir 137180 Remote 5900 3100...
I put new batteries in and found the code that coincides with my tv. The satellite mode button works fine,(I can get on "guide" and turn the channels) but the tv mode button is not allowing me to turn up...
This is due to the code in the book that is programable to the remote not being the same as your TV's. This is due to manufacter dates of the remotes versus the TVs. You could get a 20.0 remote which is the newest and a learnable remote from dish to serve this purpose.
Thanks for using Fix Ya.
Feb 12, 2010 | DISH Network 135899 Remote Control
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
Akai LCT3785TA
You need to contact dish network to get a manual for remote control. Each TV brand has one or more codes that will allow you to power TV on or off, and adjust volume. Since Dish Network uses a specific remote to operate that particular receiver you will need them to either send out a technician to program for your TV, or send you a new remote that has a manual. Allowing you to do the setup yourself..Good Luck
Oct 19, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Controlling my Sylvania LC320SS8 with my Dish Network remote
Try these Sylvania codes: 10054, 10030, 10171, 0030, 0054, 0171, 1944, 1963.
These weren't listed in Dish Receiver manual.
Apr 09, 2008 | Sylvania LC320SS8 32 in. LCD Television
DISH Network IR Remote Control Logo
225 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
