Question about Epson Expression 1680 Flatbed Scanner
SORRY MAY BE A BLONDE QUESTION
PLEASE CAN I SCAN NEGATIVES WITH A CONVENTIONAL FLATBED SCANNER
TAR EVERSO.
YVE
  • herwotdus Feb 17, 2009
    THANKS FOR TRYING ..SEE I KNEW IT WAS A BLONDE QUESTION
    YVE
    Brigadier General:
  • 5,158 Answers
Well now there's something i've never tried.... i would suppose you can but they will likely turn out like... well negatives
Robert
Posted on Feb 17, 2009
  • Roberta Smith
    Roberta Smith Feb 17, 2009
    we are basically volunteers ... please consider bumping that rating up to at least a helpful and even better a fixya thanks
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
I want to buy negative scanner attachment adopter
all kinds of scanner can scan in negative results, check your scanner program availability, or scan it using with other programs like ADOBE Photoshop
Jun 18, 2009 | Umax Astra 6400 Flatbed Scanner
Negative scan
The HP web site says the hpscanjet 2400 does not have a transparency materials adapter, so it would seem that you can not scan slide or negatives.
Jun 14, 2009 | HP ScanJet 2400 Flatbed Scanner
My scanner will not scan negatives
Most scanners aren't designed to scan negatives. (Of course the manufactures would never want to tell you their product CANT do something).
Flatbed scanners typically have a light on one side.
To scan negatives properly, you need to have a scanner that has a backlight, or a second light in the bed's lid that you fold down.
Canon USA, Inc. make a few flatbed scanners that have backlights. They range from $60 to $180, depending on the features and resolution you want to pay for.
Please see the below link. This is a more expensive one, but is shown just so you get the idea. In the pictures, note specifically in the picture that shows the lid open, how the white backing on the lid can be removed from a clip at the top. Underneath, is the backlight and clips designed to hold negatives in with the included frames.
http://www.newegg.com/Product/Product.aspx?Item=N82E16838111015
May 04, 2009 | Epson Perfection V200 Flatbed Scanner
I am tring to scan my 35mm negatives
Select scan. When the window pops up look in the upper right hand corner of the window. You will see select source: drop down menu give you choices which includes negative film. Just select it. Then drop negatives into holder. Oh, make sure you remove the cover sheet that slides in and out of the cover.
Mar 19, 2009 | Canon CanoScan 5000F Flatbed Scanner
Scanning documents for report cards
It will scan pdfs but you would need adobe professional to add the data for each student. It cannot scan a document and make it into a Word doc because this is essentially an image scanner and .doc files, etc. have more complex embedded information that cannot be captured by a scanner because that information is not visually present (i.e. exact font size, type, formulas, etc.). You'll have to find some other way- sorry!
Jan 06, 2009 | Canon CanoScan 8400F Flatbed Scanner
Scanning negatives
Are you saying
The scanner worked with negative with XP but not with Vista?
Uf so this is a drver problem
Two thing to try- 1, Go to Programs/Accessories/system Tools Compatability Wizard and rest to XP then try.
Or 2 Google for suitable Vista Driver
Jun 11, 2008 | HP Scanjet 4070 Flatbed Scanner
Driver please for this acer scan to web 3300u flat bed
please download linux driver following link
http://www.acercm.com.tw/tw/service/scan/drivers/Linux/sane-1.0.4.tar.gz
Download-it, ungzipped and untarred it, and it was a modified version of SANE - Scanner acess made easy (snapscan backend)!
Took a look at the scripts it was carrying, and since everything look good, I decided to give it a try.
I run the ./ezsetup script and almost worked at first try.
Loaded the usb file system : mount -t usbdevfs none /proc/bus/usb, changed from egcs-2.91.66 to gcc-2.96, and it not only correctly compiled but it worked!
[nuno@localhost nuno]$ scanimage -L
device `colorusb:/dev/usb/scanner0' is a Color FlatbedScanner21 flatbed scanner
Mar 21, 2008 | Acer Scan to Web 3300U Flatbed Scanner
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Epson Expression 1680 Flatbed Scanner Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
