Question about Peavey Audio Players & Recorders
No sound from power amp
The light comes on but no sound comes out of the speaker. What can I test and replace to get it working again?
  • 2dcapcom
    2dcapcom Feb 18, 2009
    thanks for looking,
    it is a peavey minx 110
  • 4,234 Answers
Without knowing which model you have, there is little I can do. Can you please update this with the model number? Also, are there any other indications that the amp is trying to work?
Posted on Feb 18, 2009
The subwoofer just quit working the green light is on sound comes out (here voices) the subwoofer no bass
if the light still comes on then the fuse is still good....
a possiblity exists that either the amplifier or the actual speaker itself went bad....if you like you can dissasemble the the subwoofer to access the insides....a simple test....if you connect the driver to another amp (any amp will do as this is just a test) and it makes sound then chances are your amp is bad or just a loose connection.
Aug 30, 2010 | Sony SA-VF700ED Speaker
Red light is on and subs won't play all the wires are connected correctly it all of a sudden just stopped working one day idk y
sounds like the amp is in protection mode. try disconnecting the subs and see it the light changes to green. if it does then the subs are your problem. if the light was allways red while it was working then the subs may be disconnected inside the box or have gone bad. try using a diffrent speaker and connect to the amp.
Feb 06, 2010 | Audiovox Car Audio & Video
Amp powered protection on no sound
Disconnect the speaker wires and test again. If the protection light goes out, check your speaker wires at the amp and to the speakers. re-connect speakers one at a time and test until it goes into protection or your problem is solved. If a speaker connection causes the amp to go into protection, test that speaker with a meter or put it on a different channel. may be a blown speaker. If you need more help, post a comment and I can help you troubleshoot more.
Jul 06, 2009 | Car Audio & Video
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Kicker DX350
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Sep 22, 2006 | Kicker DX350 Car Audio Amplifier
52 people viewed this question
Top Peavey Audio Players & Recorders Experts
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
