Question about Sanyo PLC-XU73 Multimedia Projector
Laptop is not being connected
Hey guys,
We have this PLC-xu73 at University. It is used by M.A students for pps presentations.
However, the problem is that the projector won't work with all of our laptops.
It does work with some but not all the laptops connected to it. I will be really thankful if anyone can help, because I have a presentation soon, and it seems it won't work with my laptop.
ps: if there's a driver, then it is not available at university for some reason. They say they lost the manual and driver.
  • 1,602 Answers
THE PIN CONNECTION MAYBE DIFFERENT IN THE OTHER LABTOPS YOU WOULD HAVE CONTACT THE VENDEER AND CHECK THE PIN OUT FOR THAT PORT AND SEE IF THEY ARE THE SAME.
THE COMPUTER CABLE SPACIST CAN HELP YOU, CABLE CONNECTION, CABLE AMERICA, AND CABLES TO GO.
ROD
Posted on Feb 17, 2009
Which is the cheapest accommodation in Southampton?
You can get quality accommodation in Southampton. You don't need to search, I took help from accommodation agencies who helped me to get a student house share southampton. And they are charging me really less and the quality of the house is excellent. I have good room partners too who are from the university of southampton. And the distance to the university is walkable. For more info. please visit this page: http://www.poshpads.com/southampton-student-accommodation.php
Student Accommodation Southampton
Sep 16, 2014 | Office Equipment & Supplies
I put a new bulb in a sanyo plc-xu73 projector still no light how do i test the bulb to make sure its not bad
There's no test equipment for DLP lamps.
The only way to test the lamp is with a working projector.
I am a Tech many times, I can tell by a visual inspection.
If you purchased a cheap lamp, or from someone beside a Sanyo dealer then, you may have a bad lamp.
www.aaatvservice.com
Jan 26, 2012 | Sanyo PLC-XU73 Multimedia Projector
Hello I cannot connect my sanyo projector PLC-XU73 with labtop can anybody help me how to do it? andjust resolution of screen or what
Hello, Here is a step by step process on how to connect a laptop to your projector.
Start with projector and laptop turned off
Attatch all cables required, power and signal (VGA) for both proj and laptop
At the laptop end, ensure that the VGA is securely fastened using the screws attatched to the cable
at the projector you should notice there is more than one socket that the cable can go in, you need to make sure you are connecting to the INPUT not the OUTPUT.
Turn on the projector and allow it to go through it's start up process, once started select the input that you plugged the cable into (usually INPUT 1, PC, or VGA).
Turn on Laptop and wait for it to do it's start up process, log in if needed.
If by now you don't have an image on screen, you'll need to try and change your output arrangement.
THE FOLLOWING IS FOR PC ONLY, NOT MAC
This is very simple, but a bit awkward to explain so bare with me. To do this you need to hold down the 'Fn' key and press the correct F# key, this changes with every brand of laptop, so for instance HP and Compaq is F4, IBM is F7, Toshiba is F5. You may be able to tell just by looking at the symbols on your F# keys. If you don't know which it is you'll have to look it up (I don't know all of them sorry). So if you had a HP laptop you would hold the 'Fn' key and press the 'F4' key.
You should now have an image on your screen, if you have lost the image on your laptop's screen after doing the previous step, press the Fn F# again, and it should send to BOTH screens.
The projector that your using is designed to run a resolution of 1024x768. When the image came up on screen it should have changed it automatically, however if it didn't do this:
right click on your desktop and click on 'properties'
click on the settings tab up the top
under 'screen resolution' you should see a horizontal slide bar move that to 1024x768
Click 'apply'
If a box pops up asking you to confirm the setting click yes quickly or it will revert back.
I hope this helps,
Mar 18, 2011 | Sanyo PLC-XU73 LCD Projector
Referral key for microsoft office home and student 2007
You can buy the student version. The difference between the student & professional versions is the amount of functions that are already supplied. To get the key, you must purchase the program.
Oct 31, 2009 | Microsoft Office Home and Student 2007...
Red vertical lines from top to bottom. Red lines,white lines in a uniform pattern
Try to change your VGA cable if the problem occur your A/V board was deffective.
Oct 23, 2009 | Sanyo PLC-XU73 Multimedia Projector
No way to get simultaneoulsy my videos on the laptop monitor and on tne projector PLC XU 73 card : ATI Radeon X700
Most laptops have a Function (Fn) key in an alternate color (blue maybe) from the usual key text color (white usually).
By pressing this key, along with another key that has text of the same (blue) color, perhaps labelled with "LCD/CRT" or a pic of a monitor, or of 2 squares - one single square and one double "square in square", you can toggle between the modes of:
1. Laptop display only,
2. external display only, or
3. Both displays.
Be sure to check your laptop model manual for specific details to make sure this is possible.
Jun 09, 2009 | Sanyo PLC-XU73 Multimedia Projector
WIRING NEEDED TO HOOK LAPTOP TO TV FOR PPS PRESENTATION
well you need to use the VGA TO VGA Cable and some toshiba laps needs to set it on that mode by pressing Fn+F10.
May 31, 2009 | Computers & Internet
Project is not projecting my laptop's image
You need to go into the control panel and see if this model will support dual display.
Feb 17, 2009 | Dell Latitude D500 Notebook
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
Sanyo PLC-XU73 Multimedia Projector Logo
191 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
GarryK
Level 1 Expert
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
