Question about Brother IntelliFAX 4100 Laser Fax
Black mark on right side of paper
This mark appears on all faxes sent, and all confirmations, but does not show on reports printed. I have replaced both the toner and the drum. When sending out faxes, they are being received as totally black.
Bothered with Brother
  • bpath Feb 19, 2009
    My problem sounds similar, except all sent faxes have a 1-2 in. black stripe. When a fax report prints I see the black stripe also. Any faxes I receive are fine.
  • bpath May 11, 2010
    Where can I get documentation that allows me to identify the compents you mentioned and acces internal parts?
The scanner is not working properly, not the printer part of the unit.
The LED array is not lighting causing black scanned prints.
Resolder the contacts in the LED array...probaly a cold solder joint.
Posted on Feb 17, 2009
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
how many pages were sent, etc.
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
Nov 25, 2010 | HP 1040 Plain Paper Inkjet Fax
How do I print a fax confirmation AFTER I've sent a fax on the HP L7590?
The product can print confirmation reports automatically for each fax that is sent and received.
Printing fax confirmation reports
  • The default fax confirmation setting is Off . Use these instructions to enable printed fax confirmations.
  • Press Setup on the product control panel.
  • Press the right arrow button until Print Report appears on the control panel display, and then press OK .
  • Press the right arrow button until Fax Confirmation appears on the control panel display, and then press OK .
  • Press the right arrow button to select the appropriate option (listed in the following table), and then press OK .
Sep 25, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
You either have some white out or some other dirt on the scanner or some sections of the scanner are bad. Open the area where your originals feed into, and look for about a 1/2 inch wide strip of glass, that is the scanner window. When that gets dirty, or fails, that causes the problem. Most likley dirty, some whiteout or ink on the scan window.
Mar 18, 2008 | Brother IntelliFAX 4100 Laser Fax
SHARP UX B700 TRANSMISSION REPORT
Does your machine show anything on the confirmation report like fax number,duration, pages sent, etc. or is the image just not being printed. If you have properly programed machine to show image on the confirmation report. I don't see anything that will cause that except your origianls may not right side up/down.
Thanks,
Mikey
Mar 06, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Brother IntelliFAX 4100 Laser Fax Logo
254 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
