Question about Itronix Husky FEX21 Pocket PC
Husky fex21 will not turn on
I have a husky fex21 that when plugged in will show a continuous red light, indicating a fully charged battery, but will not turn on. I have tried to do a soft restart with no success. Please help me turn this on.
  • jasongeck Apr 03, 2009
    irvin - did you solve issue? I am having same issue....
Hi, disconnect from AC power then remove battery and then re install it - this sometimes works if there are re charging problems. Also try doing a number of soft re starts and try turning on with AC power connected. If all else fails do a hard reset - you will lose any added programs that are on the units memory but not if they are on a CF card.
Good luck
Posted on Apr 22, 2009
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
M670 notebook not charging when plugged in
Charge the Battery fully before first use . The red flashing indicator shows that the battery has been deeply or fully discharged . Please Connect your laptop to AC power source and let it remain for well over 10 hours atleast.If the battery pack is alive it might recover and start working normally.
Apr 27, 2008 | MSI Megabook M670-046US Notebook
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Charging H550
The indicator light turns red when the battery is
charging. It may take up to 1 minute for the
indicator light to turn on. When the headset's
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Husky handheld fex21
have you tried discharging the batteries then reconnecting as a new partnership?
Oct 18, 2007 | Itronix Husky FEX21 Pocket PC
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
Itronix Husky FEX21 Pocket PC Logo
155 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
