Question about Philips Universal PH301S Remote Control
The set button does blink twice when I try to get the codes for
A RCA tv. tv blinks once then the set button blinks only once
  • 1 more comment
  • pjlkimpam Feb 17, 2009
    I am trying to use the philips 3 function universal
    I am trying to use the remote to work an RCA tv when I press the set button it only blinks once not twice cant go any ferther.
  • albert getty
    albert getty May 11, 2010
    what are you trying to do?
  • 547 Answers
Hold it down tell it stays lit or try to go farther
Posted on Feb 17, 2009
I have a 25-inch RCA television and a one for all remote URC-4330BO4 I need the code for the TV.
The manual for your control lists a bunch of codes for RCA:
0047, 0747, 1047, 1147, 1247, 1347, 1447, 0090, 0051, 0093, 0019, 0679, 0018, 0135, 0038.
They also list the code search steps to see if some other programmed code will work if none of the listed ones do:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Jun 29, 2011 | RCA Televison & Video
What are the comcast remote codes for Sony HT-SS370 home theater system?
If you have this comcast Universal Remote - Red OK/Select Button here are the codes Sony 11100, 10000, 11317
if this doesn't work use the search mode
Searching For You our Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TVTV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TV key will blink twice.
4. Press and release the digit 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TVTV key will blink twice.
7. To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the device you are searching for.
Checkcking the Codes
If you have set up the remote control using the Searching For Your Code
procedure, you may need to find out which five-digit code is operating your equipment. Perform the following steps after setting up your devices to find out which five-digit code operates your equipment. For example, to find out which code is operating your TV:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
3. Enter 9 - 9 - 0. The TV key will blink twice.
4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks =3) and write down the number in the left most TV Code box (at end of this section).
NOTE: If a code digit is "0", the selected mode key will not blink.
5. Repeat step 4 four more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the fifth digit. Finish writing down the code in the TV Code boxes (at end of this section).
It can be a pain but once you get it down its a cake walk.
Jan 23, 2011 | RCA L42FHD37 42 in. LCD HDTV
I need the code for a rca tv
To control an RCA tv with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0047, 1047, 1147, 1247, 1347, 1447, 1547
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 23, 2009 | One For All URC-3021 Remote Control
I do not have the set up instruction manual with
To control an RCA TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
Hope that helps.
Nov 05, 2009 | One For All URC-3021 Remote Control
How do I program my urc-4021BOO One For All remote to operate my RCA Tv (E13309)?
First turn on the tv manually. Next press the TV button on the remote once. Then hold the set button until the light blinks twice. There are 7 codes for RCA tv's and the model is not specified. After each code entry, the light should blink twice again. The codes are : 0047, 1047, 1147,1247, 1347, 1447, 1547. After you enter a code try the power button on the remote and the set should cut off.You have to start over with the set button with every new code. When you find the right code the tv will turn off. I hope this helps. The link for the owners manual is: http://www.oneforall.com/uploads/support/cc5ef1b7b389da162d2ac97bb9e94210.pdf Thankyou for using fixya. I'm glad to help.
Nov 04, 2009 | RCA Televison & Video
I need help finding my code for my TV. Its an RCA Colortrack
1) Turn on your TV.
Hope that helps.
Oct 31, 2009 | One For All URC-3021 Remote Control
I need the RCA codes for this remote
1) Turn on your TV.
Hope that helps.
Oct 29, 2009 | One For All URC-3021 Remote Control
RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Oct 11, 2008 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
