Question about Goodman GMS90703BXA Heater
Goodman Propane heater 2yrs old Sound like a flame thrower
I noticed two things, One that we've bin going through a whole lot more fuel and 2nd when the heater kicks on it sounds like a flame throwers and has been getting louder , it come to the point that the heater is my new alarm clock. Could it be in the adjustments and if so how can it be repaired
  • ruiz539 Feb 19, 2009
    Thank you for the advice, I will call the company that installed same.
  • 1,420 Answers
The sound you are hearing is gas burning in the throat of the burner. It is usually an indication of a air/gas mixture. Have your gas company investigate the gas pressure. This would explain slightly higher usage because the furnace is not putting out all of its heat.
Posted on Feb 18, 2009
Pilot light blowes like flame thrower when lit on bosch 125 blp
Remove the pilot injector from old unit and fit into new unit
Apr 03, 2014 | Bosch Water Heaters
When we lit the sunrite heater we had flames on the face of it. we assume that this is too much. we did have the propane turned down as low as it would go.
sounds like you managed to get liquid propane into the pipe work. spectacular flame thrower, yes but not very safe . Take heater outside . disconeect the feed tube and regulator leave for the liquid to evaporate. Set the controls to max heat probably allow a day or so to be sure before re connecting and trying again
Dec 04, 2013 | Mr. Heater Heating & Cooling
Coleman model# 2430-730
It is an old one, Propane? or gasoline/camp stove fuel?
If propane and will not remain lit- replace the thremocouple- that thing beside the pilot flame that does not seem to do anything- it holds the gas valve open when flame is present.
If gasoline/camp stove fuel and will not light or does not stay lit- clean the "generator" which is under the asbestos shell. It is not even acknowledged by Coleman anymore.
Dec 22, 2011 | Heating & Cooling
I have a Goodman gas (propane) pack heat pump which was installed a month ago on our new home. There is a horrible smell coming from around the unit, and some soot is on the propane pipe just in front of...
Please SHUT IT DOWN !!!!!!!!! Contact the installer because the LP propane conversion kit has probbaly NOT been installed.Any gas system should NEVER make any soot.
Oct 31, 2011 | Goodman GMS90703BXA Heater
Knocking sound caused by the flame sputtering.
I have heard of noises coming from the inducer fan as it start to build up with condensation but the noise coming from the flame is new to me. Gas pressure or a cracked heat exchanger could cause the flames to float around out of the manifold but that is about all I can think of
Jan 07, 2010 | Goodman GMS90703BXA Heater
I have a goodman gmp100-4 gas furnace and the gas comes on but shuts off in around 30 seconds, then tries again and the same thing... can i get some help please?
On the last gas venturi tube there should be a flame sensor located in the flame to prove it exsists, if its coroded the spark can,t jump back thru the moisture molecues in the gas to prove it has a flame to tell the circuit board to keep the gas comming. Just reomve the flame snsor and sand itand replace itback. T. Y. V. M.!
Dec 01, 2009 | Goodman GMS90703BXA Heater
The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Flame dies after a couple of seconds
yes there is look in the flame path of the last burner should be a one wire and the sensor looks like a hard L shape wire take it out and clean with steel wool or real fine sand paper
Jan 03, 2009 | Goodman GDS80904BNA Open Flame Heater
Adjusting goodman propane burners
Yellow flame can also mean inadequate gas pressure. Do you have a manometer? If not, call your gas company for a check.
Oct 09, 2008 | Goodman GMS90703BXA Heater
Goodman GDS80703ANA
Yes, goodman offers a kit. However you will need a gas technician adjust the pressure for you. The whole conversion will take about an hour. The kit may cost $50 and labor is anyone's guess. Call your gas company and give then the model and serial nimber. They can order it and install it.
Nov 19, 2007 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
