Question about Sharp AR-157E Copier
AR-157E blank page when using automatic feeder.
My copier no longer produces a copied image when run through the automatic feeder. The paper comes out blank. It copies fine when placed on the glass. Any toubleshooting steps I can follow?
Thanks! Dave
  • 29 Answers
You night check to see if your cable to the copier is connected but this problen iv seen several times not worth fixing the main pcb is usally gone as for as working with the feedder
Posted on Mar 10, 2009
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
Sharp ar-m208 copy problem
Do you mean really faint and light or completely white, blank?
Jul 09, 2009 | Sharp AR-235 Copier
Can you bypass a low toner alarm on a AR 157E to allow the unit to run paper through the paper path
Yes in service mode. But you will not make a copy with out any toner in the copier.....
May 06, 2009 | Sharp AR-157E Copier
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copier produces no image
if you are getting blank pages from you machine then the scan lamp is blown or something else is cause but if you lift the lid and hit start and dont see the lamp come on then the lamp is the issue
Feb 02, 2009 | Canon PC-420 Copier
Xerox Copycentre C20 Prints nothing but blank pages
Is the paper (copy) truly blank? Please look very close at the page. It sounds like the coratron (charge) wire (s) are broken. These are thin wires this use electrical charges to transfer the image onto the paper. You can go online and order a small spool of the wire and restring the wire. You do not have to be a doctor to do this repair but a steady pair of hands is very good. NOTE:::::: pay attention, most of the coratron units use tiny springs... so look and listen in case it falls out. You can restring with out the spring but it is better with the spring. Remember when stringing the wire, not loose but do not over tighten.
Dec 26, 2008 | Sharp AR-M455N Copier
I am trying to copy a document from the automatic feeder. The feeder will not pick up the document and instead of getting a copy, I get a blank page. I have cleaned the rollers and nothing has changed.
I have noticed that these rollers can wear to the point that they no longer make proper contact with the paper regardless of cleaning. (Especially if you frequently print to paper of varied thicknesses) Try using a card stock sheet in the automatic feeder, if the problem goes away, you will need to replace the rollers to print to standard letter.
Aug 22, 2008 | Office Equipment & Supplies
Not photocopying
Open side, look at black assembly on the door, there is either a black spongy roller there or two wires in a black assembly,
1- wires may be broken resulting in blank copies
2- roller out of place
3- HVT (high voltage transformer) not working
Jun 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Copying problem
check paper through paper cassette, then through bypass,if fault occurs on both, it is possible the registration roller area is possibly faulty.
There are other reasons for this relating to image formation, but please start with paper feed.
Jan 29, 2008 | Sharp AR-207 Copier
SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Nov 07, 2007 | Sharp AR-507 Copier
Sharp AR-157E Copier Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
