Question about Averatec Computers & Internet
Computer will not turn on.
IS the power battery the power pack, if not where is it?
  • 265 Answers
New charger, if not the power supply inside could of blown, this could be many of reasons, i.e if u knocked the adaptor and it blew the board
please rate my solution
hope this helps
Posted on Feb 17, 2009
My aceraspire4330 wont power on
you can try the power system check by doing the following:
To verify the symptom of the problem, power on the computer using each of the following power sources:
1. Remove the battery pack.
2. Connect the power adapter and check that power is supplied.
3. Disconnect the power adapter and install the charged battery pack; then check that power is supplied by
the battery pack.
If you suspect a power problem, see the appropriate power supply check in the following list:
"Check the Power Adapter"
"Check the Battery Pack"
Unplug the power adapter cable from the computer and measure the output voltage at the plug of the power
adapter cable. See the following figure
1. If the voltage is not correct, replace the power adapter.
2. If the voltage is within the range, do the following:
* Replace the System board.
* If the voltage is not correct, go to the next step.
NOTE: An audible noise from the power adapter does not always indicate a defect.
3. If the power-on indicator does not light up, check the power cord of the power adapter for correct
continuity and installation.
4. If the operational charge does not work, see "Check the Battery Pack"
Pin 1: +19 to +20.5V (Centre pin)
Pin 2: 0V, Ground (Shielding / Surround)
To check the battery pack, do the following:
From Software:
1. Check out the Power Management in control Panel
2. In Power Meter, confirm that if the parameters shown in the screen for Current Power Source and Total Battery Power Remaining are correct.
3. Repeat the steps 1 and 2, for both battery and adapter.
4. This helps you identify first the problem is on recharging or discharging.
From Hardware:
1. Power off the computer.
2. Remove the battery pack and measure the voltage between battery terminals 1(+) and 6(ground).
(Terminal 1 is closest to the edge, Terminal 6 is closest to centre)
3. If the voltage is still less than 7.5 Vdc after recharging, replace the battery.
To check the battery charge operation, use a discharged battery pack or a battery pack that has less than 50% of the total power remaining when installed in the computer. If the battery status indicator does not light up, remove the battery pack and let it return to room temperature.
Re-install the battery pack.
If the charge indicator still does not light up, replace the battery pack. If the charge indicator still does not light up, replace the DC/DC charger board.
Jan 20, 2015 | Acer Aspire One PC Notebook
Reset power on PW
There is three different passwords on Lenovo, but if you really activated POP (power on pass), then you can remove it by removing battery and bios battery as you can read from manual page 35 http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/43y6630_01.pdf
To remove a POP that you have forgotten, do the following:
(A) If no SVP has been set:
1. Turn off the computer.
2. Remove the battery pack.
For how to remove the battery pack, see "1010 Battery pack" on page 63.
3. Remove the backup battery.
For how to remove the backup battery, see "1100 Backup battery" on page 79.
4. Turn on the computer and wait until the POST ends.
After the POST ends, the password prompt does not appear. The POP has been
removed.
5. Reinstall the backup battery and the battery pack.
May 09, 2014 | Lenovo Thinkpad T500 2243 Notebook
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
My lenovo x61 show a lock hence does not boot. I had set up a bios password which i can't remember.could u have an idea?
For a desktop computer:
Depending on the motherboard of the computer in question you can:
  • Locate and change the position of a jumper that will clear the BIOS settings.
  • Unplug the machine and pull out the battery that maintains the BIOS settings in RAM.
For the Lenovo x61 and other laptops:
Follow this link to see the laptop manual: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/42x3550_04.pdf
2. Remove the battery pack. (See "1010 Battery pack" on page 60 of the above link.
3. Remove the backup battery. (For how to remove the backup battery, see "1140 Backup battery" on page 82 and page 65 of the above link).
3a. You must remove the keyboard and battery pack to access backup battery.
3b. Remove 4 screws with keyboard icon to remove keyboard.
3c. Gently push the keyboard forward.
3d. Then lift up the keyboard slightly.
3e. Detach the keyboard connector.
3f. Remove keyboard.
3g. Disconnect the backup battery.
After the POST ends, the password prompt should not appear. The POP has been removed.
5. Reinstall the backup battery and the battery pack and the keyboard.
Good luck and thanks for using FixYa.
Mar 03, 2011 | Computers & Internet
I have Hp dv6000 laptop, It was working fie before but now it just doesn't turn on. I can see the power lights on front of laptop, It has the power but it doesn't turn on.
Take the battery out and see if it will boot up. If it does then your battery has gone south and probably needs replacing. Lap Tops have Li-ion battery packs and a safety feature built into the battery pack is if the voltage falls below a safe level for the charging circuit to safely charge the battery without over heating, a chip inside the battery pack sends a signal to the computer,"Do not turn on" This will prevent the battery from causing a fire.
Jan 10, 2011 | HP Pavilion dv6000z Notebook
Blank screen
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
vote me if you find your solution
Jul 07, 2010 | Sony VAIO R505JL Notebook
Acer Laptop Aspire 5050
Hi, you can do a simple check to establish which is at fault, your battery or power pack.
If your computer runs OK on the power pack then the battery is at fault. If the computer will not run on the power pack then the power pack is the cause.
Regards mistyman
Aug 14, 2008 | Acer Computers & Internet
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
About my batteries
When Plug the AC power cord, what the power indicator light want turns on, indicating that charging has begin.? The battery pack has a limited lifespan. Battery pack duration will decrease with repeated usage and age. If the battery pack duration declines greatly, it may be time to replace the battery pack. Hope this helps
Oct 30, 2007 | Sony VAIO FRV28 Notebook
Computers & Internet Logo
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
