Question about Dynex DX-LCD19-09 19 in. LCD TV
Swtiching to Digital tv
How do I change it over to digital channels. My tv is saying no signal, and my is hooked up to a cable cord. Help me!!!!!
  • dariceclayto Feb 17, 2009
    Okay I still did all this and still nothing!!!
  • 362 Answers
If you are connected to Cable TV service you are probably already setup, but here are a few things to check for.
  1. From the Menu, make sure the tuning band is set to Cable and not to Air or Antenna.
  2. From the Menu perform an Auto Channel Search.
That should be all you need to do.
Now if you want the best High Definition picture, believe it or not you will need an Antenna, depending on your location you will be able to pick up OTA (over the air) channels in the purest form.
I can help you with this also, let me know. Lone99star Please rate this solution.
Posted on Feb 17, 2009
  • Jason Morris Feb 17, 2009
    With the remote press the Input button and cycle through all inputs to find the signal.
    You will need to check and make sure you are receiving a signal. If you can connect another tv to the cable.
    Let me know your findings.
    Lone99star
I tryed retuneing it but no channels get picked up?? i know the Ariel works so idk what to do someone help please!!
Number one is make sure you have the tuner set to cable if it is cable your hooked to, number two if it is air and not cable make sure you have the rabbit ear antenna hooked up. Number 3 if you are in an area that has changed to digital cable, ie most of the world you will need a digital box between your TV and cable or air antenna.... digital is short bits of data transmitted through the cable or air and essentially you need a Translator between the signal and your TV to translate the signal back to analog so your TV can understand the picture... this change has happened in order to free up more bandwidth in each country and allow for more channels to be used... kinda like a sim card vrs an old encyclopedia... the sim card can hold a whole library's worth of books in a very small space.
May 18, 2016 | Sony FD Trinitron KV-28FQ75 28" TV
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
Sansui HDLCD1908B Television
call you digital cable provider
Jul 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
May 09, 2011 | Televison & Video
My tv will scan and receive channels on a antenna but will not pick up channels on a cable scan with a good cable and a proven good cable signal
if you are not using a cable box and trying to connect cable directly to tv you will get very few channels since they are all digital now and most are scrambled
you will need to hook that cable to the input labled 'QAM' and program tv for digital channels
if you are coming out of a 'cable box' you just need to hook up video cables to an input on tv and change tv to that input - no scanning necessary
hope this helps - if not write back with more details and i will try to help more
good luck!
Mar 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Digital signal for my Sharp Aquos
Hi
On the TV menu did you change it from Cable to ANT?
Mar 13, 2010 | Televison & Video
I am trying to hook up a digital labs, 19'' lcd tv/dvd combo and when i do the initial channel scan it doesnt pick up anything from the satelite at all, i have hooked them toghther anyway i can think of...
Most HDTVs have ATSC, QAM and NTSC (analog) tuners. It sounds like yours does not have an NTSC (analog) tuner. QAM tuners only pick up digital cable channels. You may need to switch to your cable company's digital service if your not already on it. Call your cable company for further info
Dec 26, 2009 | Televison & Video
Just bought a LG 32 LH20.I tried just screwing the cord that was hooked up to my other tv from my cable box into the new tv but it just says no signal.I have time warner cable with Dvr if that makes any...
You need to do a first time set up. The TV has to find what channels you have. You need to set the Tv to cable as your input and then auto scan for both analog and digital channels.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
Dynex DX-LCD19-09 19 in. LCD TV Logo
305 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
