Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
Fax/printer connected on ADSL Line - the Internet does not work
Have connected a new Canon ImageCLASS MF4370dn Laser All-in-One ... printer/fax on same ADSL telephone line - now the ADSL doesn't work - anyone knows of a possible solution please? Thank you.
    Genius:
  • 2,120 Answers
No, fax machines are analog devices
Posted on Feb 17, 2009
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Can canon mf4370 fax on dsl line
Fax machine operation can be interrupted by DSL lines, however, because the DSL signal is also transmitted through phone wiring. This can result in a loss of data in the fax if steps are not taken to prevent it. Fortunately, this is not a difficult thing to fix.
Items you will need
  • DSL filter
Step 1
Unplug the fax machine from the phone jack.
Step 2
Plug your DSL filter into the phone jack. DSL filters are specifically designed to eliminate interference from the DSL line on your phone line.
Step 3
Plug the fax machine into the phone line jack on the DSL filter. You can now use your fax machine and DSL line at the same time without risk of data loss or interference.
Feb 05, 2013 | Canon ImageCLASS MF4370dn Laser All-in-One...
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
System error e255
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mfp 4320d system error e255
dear sir,
this is manjunath my canon laser jet printer it's given problem the problem is system error E255. it's shown on the printer.. plz given the sulation... my contect number is +91 9916062560
Jul 08, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
After installed the Window 7, MF4360dn scanner is not working!
Hi there
Not work you need to find the windows 7 printer driver for it and it could be a job trying to find one as they are still selling there printers with xp drivers only, sorry.
Feb 21, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
How can I adjust the fax ringing sounds? It's too
1. Press the menu key
2. Press the left or right arrow to show VOLUME CONTROL, press OK
3. Press the left or right arrow to show CALLING TONE, press OK
4. Press the left or right arrow to select volume (0 - 3), press OK
5. Press the STOP/RESET key.
Jan 19, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Multiple fax copies only 1 or 2 get through
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
Jul 09, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
242 people viewed this question
old marine
old marine
