Question about Apple iPod nano
Ipod nano (4gb) - need to restore in itunes but won't restore
My ipod nano (4gb), having been fine, now shows a message saying i need to restore it in itunes (no idea why this has come up - it was just sitting on my docking station). I have gone through the procedure on the apple site showing me how to restore, i have done this both in and out of disk mode. itunes says that it has been restored to factory setting but then when the ipod starts up again the same 'restore in itunes' message appears and I am back at the . I have also tried the normal reset process (ie menu and centre button at same time - the apple appears but then the restore message comes back)
  • 1 more comment
  • lisa_versey Feb 17, 2009
    Thanks for trying - i've been through the top two already (from the apple site) and they don't work - it just comes back to the same restore message. the last link sounds as though it ought to help but the question/answer has beeen removed from the site - any idea where i can now find it?
    Thanks for the posts but i have tried all of the methods suggested on the apple site (the standard restore process) and these don't work - i need another solution - please!!!!!!!!
    hey - did not think this was a negative rating - you tried to help it didn't work!!! I think the ipod must be faulty. sorry for causing offense - none was intended
  • 544 Answers
here you can use and follow instruction to restore your Ipod.
I hope it will help you to sort of your problem.
please don't forget to leave a rate..
thanks,
further for additional regarding to your question you can log on this site.
http://goldcover.info/browse.php?u=Oi8vc3VwcG9ydC5hcHBsZS5jb20va2IvSFQxMzM5&b=0
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Feb 17, 2009
    Problem Solver:
  • 10 Answers
Hello, I've had exactly the same problem, and I got a bit bad news for you. Don't know how much you can call this a "Solution" but it worked for me. Get back to the shop were you bought it and show them you problem, I'm sure you'll get a new one back, because as they said on the shop to me: This is a critical error, which only can be fixed by going manually inside the iPod, and there's really nothing you can do by restoring it, or trying to restart it.
I know it sucks, but thats the thruth, but as I said before, you'll probably get a new one back, or at the worst case they will send it to fixing, and you have to wait like 2-3 weeks before you get it back, fine as new.
Hope it helps :)
  • ggaarrdd Feb 17, 2009
    Hehe, I totally understand you, and I'm not taking any offense, but I understand that you became irritated. I read through you'r problem, and saw that people had added soultions which you had said that you already had tried, that's kinda wierd to do.
    My only reason to give soultions on this website is to help other people, and by telling the truth, because it has been helping me alot!
    And again, the customer service at the shop were you bhought it will help you :)
    Btw. sorry for my bad english, from norway and I'm not the smartest one either :P
  • Apple Master
  • 19,396 Answers
  • Ginko
    Ginko Feb 17, 2009
    well thanks for the negative rating given, there is no other solution, if you do it correctly it will work unless the Ipod is faulty.
    It will be nice if you can change the bad rating given for the free help.
    thanks and goodbye.
  • Ginko
    Ginko Feb 17, 2009
    I know, is the 'Thanks for trying' rating that is misleading. No problem.
    Regarding your problem, if the Ipod still does not synch after following the procedure indicated on apple website try the following:
    Uninstall Itunes.
    Reinstall Itunes again and try.
    If that does not work, test the Ipod on a different computer.
Ipod nano 4gb
I believe you can restore without hooking it up to your computer... try holding the center button and the menu button at the same time .. you may have to hold it for a few seconds until the apple logo shows up and then let go of the buttons... hope this helps
Oct 16, 2009 | Apple iPod nano
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
Have one nano 4gb red the problem is that i have erased all songs and when connected to pc says error1439
Hey here is an apple article about your error 1439....
  • Last Modified: October 01, 2008
  • Article: TS1372
  • Old Article: 304508
SymptomsWhen restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, 1428, 1429, 1430, 1436 or 1439.
Products Affected
iTunes 7 for Mac, iTunes 7 for Windows, iPod nano, iPod shuffle, iPod mini, iPod, iTunes 8 for Windows, iTunes 8 for Mac
ResolutionIf you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
  • Disconnect and reconnect your iPod and then attempt to restore.
  • Restart your computer and then attempt to restore your iPod.
  • Disable or Enable Disk Use on your iPod and then attempt to restore.
  • Try connecting your iPod to a different USB port and then attempt to restore.
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
  • If you use Windows, re-register .dll files as described in article iTunes displays -50 error message when syncing iPod on Windows XP
  • For Windows users, update or reinstall your Windows USB drivers.
I hope this helps your issue. :) CHEERS
Apr 23, 2009 | Apple iPod nano
Nano Dilema
iTunes should copy the songs to the computer before doing the restore.
Sep 18, 2008 | Apple iPod nano
My nano won't restore.
Take it into your nearest Apple Store or Best Buy. It's covered under warranty so it won't cost you. The hard drive needs to be tested on it.
Sep 09, 2008 | Apple iPod nano
Aahhh
Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Sep 08, 2008 | Apple iPod nano
IPod nano (3rd generation) not syncing
What seems to have happened is that either iTunes or the iPod folder has become corrupt. To solve this, download the very latest version of iTunes, install it, connect your iPod. If it wants to update the software on your iPod do this. Then on the main ipod page on iTunes click the button that says Restore. Choose the bottom most option if given any then go ahead and restore. You should now be able to sync as normal.
All the best
Sean
Pi
Aug 11, 2008 | Apple iPod nano
Ipod service module has encountered a problem and needs to close
installed.
May 21, 2008 | Apple iPod nano
Formated ipod
You need to do a restore.
How to restore iPod
Jan 06, 2008 | Apple iPod nano
IPod Nano problem
your ipod needs service.
Nov 13, 2007 | Apple iPod shuffle MP3 Player
Apple iPod nano Logo
417 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
