Question about Patton PUH680-U Utility Heater
Heater coils on a aloha utility heater lights up
Problem above is stated ..is this normal when the heter is set on 1500 watts?
  • alaskianhusk Feb 18, 2009
    we have solved the problem by getting the coils to not touch each other when I got this unit the coils did not light up or glow... so it was just a matter of seperating the coils that had made contact.
  • Clark with Big Toast Dec 11, 2012
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
  • 51 Answers
It is typical for the elements to glow. The glowing is caused from the high amount of electrical flow through the coils. It is the same principal of how some light bulbs work.
Posted on Feb 17, 2009
Looking for information on an Aloha Breeze 1500 watt free standing electric wood stove fireplace heater....Model #04152
I googled ‘Aloha Breeze 04152 manual’ and found this result
https://www.manualslib.com/manual/950335/Aloha-Breeze-Kodiak-Cove-04152.html
Jan 15, 2018 | Home
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
LAK792SGSA Utility Heater: how many watts? What are the dimensions?...
This heater is 1500 watts. It's dimensions are 8 1/4 X 6 1/4 X 14 1/4. It comes in a steel case and is gray in color. Here is the company website http://www.lakewoodeng.com/Category.aspx?cid=1066
It appears that they have filed bankruptcy and now no longer make heaters...just fans.
May 14, 2010 | Lakewood LAK792SGSA Utility Heater
A small, white, plastic or ceramic part which
TRY AN APPLIANCE STORE THAT DOES REPAIRS. OR CHECK ONLINE WITH MANUFACTURER OR IF SOMEONE CARRIES PARTS FOR IT ONLINE
Feb 26, 2010 | Patton Electric Patton PUH680-U Electric...
Need to know amp draw for 1VNY1 radiant heater.
on "high" these can draw as much as 1800 watts (or 15 amps.
If there are many other loads on the same circuit, the breaker is likely to trip.
Jan 29, 2010 | Patton Electric Patton PUH680-U Electric...
What do i do to take out a heter coil
you meen the heater core?the whole dash has to come apart and the a/c system has to be discharged . not worth attempting, by unqualified person. too many booby traps. like airbags and heater door soleniods.
May 24, 2009 | 1999 Ford Explorer
What is the lower dial for, what do the balls mean ?
The red dials (I think - I can't find a pic where they are facing forward to see them) should control the wattage you have the heater set at. You can set it at 500 900 and 1500 watts usually. The first dial turned on would set the heater at 500. Turning the second dial on will set the heater at 900. And having both on will set it at 1500. And of course the more watts the more heat that will come out of the heater.
Dec 29, 2008 | Lakewood Oil-Filled Electric Radiator...
Patton PUH680-U Utility Heater Logo
168 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
ray gallant
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
