Question about Sharp 32C241 TV
Will not turn on
Like the other people, i also bought a 32c241 from best but. (I am starting to wonder is this just a coincidence or something more) when i turn the tv on, it clicks like 2-3 times and it sounds like it shuts down.. I took it to a repair guy and he thinks it might be the transformer..he is not sure but it will cost $165.. almost as much as I paid for it. Not sure if its worth it...i see the solution might be the supply or the circuit.. do not know what to do...
    Problem Solver:
The power supply is the problem! so bring it to the expert technician!
Posted on Mar 25, 2009
Anti lock brake system warning,starts & runs but wont accelerate in drive.
The ABS light sounds like a wheel speed sensor that came unplugged, or became fouled with metal shavings etc. The acceleration problem is probably unrelated. Possibly a TCC clutch solenoid.
Mar 06, 2014 | 2003 Nissan Maxima
Starter Fuse Keeps Blowing When I Try To Start My 2001 Camry
The starter has gone to ground. This is either a coincidence of age or the repair shop left something disconnected that has slapped around and grounded the starter or some of their other work has shifted around and done it. It could just be a coincidence. If it went to ground internally, it will need replacing. If something shifted and grounded it out, putting that something where it belongs and THEN replacing a fuse should fix it. Most shops reuse your starter on their new engine.
Apr 16, 2017 | Toyota Camry Cars & Trucks
Sharp Model # 32C241 shuts itself off. When I unplug it for a few minutes and try again, it starts up and runs fine. Has happened twice this week. I'm disabled and money is an issue. What causes this and...
You could try and switch outlets and see if that helps. If it continues to do the same thing access the T.V. menu from your remote and check to make sure you don't have a sleep timer set. If there is no sleep timer and switching outlets doesn't help then my guess (from my own experience) would be that it's probably on its last leg and would require a repair. If it does require a repair then you would probably have better luck buying a new T.V.
May 03, 2011 | Sharp 32C241 TV
If you delete something will your phone break down?
you need to program it
i hope i can help you
Sep 03, 2009 | Nokia 5310 Cellular Phone
I try to turn the tv on with the remote & it clicks on and off.
Probably a problem with the horizontal ouput transistor it is probably bad and/or the flyback(high voltage transformer). One or the other is probaly bad and it may be both. Horizontal ouput is definately shot if you hear a squealing sound when you go to turn it on and the flyback is probably the culprit.
Jul 20, 2009 | Sharp 32C241 TV
Car stereo disconnected and my turn signals won't work?
your fuses could be shot, wires could be shot, could be a coincidence, could be the experts at best buy LOL best way is to get it checked by a mechanic and tell him and if he determines it was obviously something caused by best buy, have them pay your bill.
Mar 31, 2009 | 1993 Ford Taurus
Gas gauge quit working
sounds like ur fuel sending unit
Mar 24, 2009 | 1997 Oldsmobile Cutlass
4Runner has high humming sound
check the front differential for fluid.
Sep 26, 2008 | 1998 Toyota 4Runner
Sharp television model 32c241
This is a power supply problem. It may be as simple as a blown fuse or as complex as a problem with overvoltage and overcurrent events within the circuitry of the Horizontal and Hig Voltage sections of the set. If it is a fuse that's simple to replace, the other well that can get kind of involved. In any event I would suggest that you get the set analyzed by a qualified Television repair person.
Sep 21, 2007 | Sharp 32C241 TV
Tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Apr 13, 2007 | Sharp 32C241 TV
Televison & Video Logo
128 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
