Question about Broderbund The Print Shop 20 Deluxe for PC
Can't print envelopes with Printshop 20
Trying to print a #10 envelope. Printshop won't print if I change the paper size to that of an envelope, says it wants the regular letter size. However, HP C5180 printer recognizes an envelope has been loaded and gives me a paper size mismatch error.
5 Suggested Answers
  • 4 Answers
SOURCE: I am using Print Shop
Go to printer properties and define the paper type/size.
Hopefully this will resolve the problem.
Thanks,
Jagdish
Posted on May 08, 2009
watcher26
  • 141 Answers
SOURCE: My HP Color Laserjet CP3505n gets an error message
check with broderbund to see if they have a driver update and check with HP at
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?taskId=135&lang=en&cc=us&prodSeriesId=3290546&prodTypeId=18972
this is the driver site for your printer.
Posted on Feb 19, 2010
  • 4 Answers
SOURCE: I am having a problem
Make sure your printer and printer settings in the program are also set for envelopes
Posted on Apr 18, 2011
multilinkent
  • 739 Answers
SOURCE: I replaced my printer with
Hi.
you should try this even if it is different version and the printer.
First design your envelope in Print Shop
Now before printing anything go to the CONTROL PANEL on your computer (start > control panel, works)
In the control panel (CLASSIC VIEW) find your PRINTER ICON double click find your printer in the list, right click, choose properties, find PRINTER PREFERENCES button at the bottom of the new window and left click, make sure that the tab labeled "FEATURES" is selected. In the "RESIZING OPTIONS" box there is a drop down menu that probably says letter by default, select the down arrow and highlight and click "CUSTOM", Here you will give your envelope a name like 'Envelope Invitation' then you will add the size in either inches or millmeters. Once you are sure the names is what you want and the size is correct first click on the SAVE button by NAME and then click OK. Now click OK in the Features window. And click OK in the printer preferences window. Close your Printers and Faxes Window.
BACK TO PRINT SHOP
maximize Print Shop again and your envelope that you were designing should be there. NOW, select either the print icon or File>Print, Next click on SETUP Where you see the PAPER drop down select the down arrow to select the proper paper. Your newly named envelope should be in the list, choose it, NOW DON'T FORGET TO ALSO CHOOSE SOURCE=MAIN TRAY. If you don't click that you might print it on photo paper, I always do that.
Please accept if it is successfully done
Regards
Posted on May 20, 2011
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
I am trying to print envelopes (using MS Word mail merge) and printer says "paper mismatch"
first change the page layout setting in the document to envelop size then try to print ..... go to page layout size option the change the paper size to envelop then try to print ......
Dec 14, 2009 | HP Officejet 6310 All-In-One InkJet...
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
Dec 12, 2007 | Minolta bizhub 200 All-In-One Printer
Printing envelopes
Print on the Envelopes
  1. Click File , then click Print .
  2. Click Properties , then click the Features tab.
  3. Change the orientation to Landscape and the paper size to envelope #10 .
  4. Click OK .
  5. Click OK again to print.
Nov 18, 2007 | HP PSC 2410 All-In-One InkJet Printer
Broderbund The Print Shop 20 Deluxe for PC Logo
192 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
