Question about Hitachi 42HDS69 42 in. Plasma Television
Sound Problems with Hitachi 42HDS69
We have hitachi plasma tv 42HDS69, picture is fine, volume went dead....Please give advice
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Posted on Aug 05, 2009
Ultravision picture dark no sound
Posted on Aug 19, 2009
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
We have a Hitachi 42hds69 tv no picture but have sound. I have sound and picture on most channels, but on 2 digital channels, I have beautiful picture, but no sound. help!!
Here is what you need to do to fix this. Call Hitachi Global Storage Technologies & request for the firmware upgrade.
1-800-HITACHI (448-2244)
They will send it to you for free. You get a small SD card that plugs into the back of your TV just below the Cable Card Slot. I wouldn'd have known it was there unless the instructions in the mail packet told me so.
To determine if you need to upgrade go Into the Setup Menu. Then, Go to Software Upgrades & look at the software version. I had 0110.xxxx. the version I upgraded to was 0125.0000 & it fixed the audio problem on 7-1 & 11-1.
now all channels work great.
THANKS HITACHI!!!
Mar 18, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Picture went out when I changed the cable channel
Check this forum thread:
http://www.avsforum.com/avs-vb/showthread.php?t=778593
Jan 27, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
Sep 03, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma Television Logo
688 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
