Question about Miele CVA4070 Coffee Maker
Descaling Hi We just descaled our system. It all went smoothly until the last minute of the process. An error sign showed up. We turned of the system and when we put it back on the display shows "Descaling" with 1 minute left. It is making noise as it was trying to run more water from the water dispenser unit (it was empty). When I refilled the container it ran the water again but the machine seems stuck on that last minute (it shows 0:01 left). If I turn the machine off and turn it back on, the display goes back to "descaling". Help. Thanks a lot. We just descaled our system. It all went smoothly until the last minute of the process. An error sign showed up. We turned of the system and when we put it back on the display shows "Descaling" with 1 minute left. It is making noise as it was trying to run more water from the water dispenser unit (it was empty). When I refilled the container it ran the water again but the machine seems stuck on that last minute (it shows 0:01 left). If I turn the machine off and turn it back on, the display goes back to "descaling". Help. Thanks a lot.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Perhaps it just needs a reset of the descaling mode. To do so:
  • switch the coffee maker off;
  • within 10 seconds, the following must be done:
  • touch pad CLEAR and hold;
  • touch pad ON/OFF once;
  • release touch pad CLEAR;
  • touch pad CLEAR 5 times;
  • on the 5th time, hold until PROGRAMMING MODE appears;
  • touchpad next to RESET DESCALE;
  • YES to lift descale lock;
  • SAVE and QUIT touch pad ON/OFF.
Good luck and thank you for using FixYa.
Posted on Feb 17, 2009
    Guru:
  • 832 Answers
Hey there! thanks for using Fixya.com!
I suggest that you check the software roblem on the electronic at the back of the coffee machine.
maybe if you change that electronic to the newest version will solve that issue.
Better check this website, might help you out as well. www.retrevo.com/support/Miele-CVA4070SS-Coffee-Makers-manual/id/19074dj285/t/2/
Thanks! don't forget to mark!! cheers!
  • Miele Master
  • 19,396 Answers
Wait a couple of hours for descaling to finish.
  • Ginko
    Ginko Feb 17, 2009
    Refill teh machine tank with water a couple of times, until the machine does not finish, and wait up to a couple of hours for descaling to finish.I know it sounds strange, but that is the way it works when the machine gets stuck in descaling cycle.
    If you want to make it shorter, try resetting the machine by unplugging power cord for five minutes, that does not work on machines that have a battery on control board.
How do I decalcify my coffee machine?
Hi Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll up until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say, "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to "Signal Descale" and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 07, 2011 | Saeco Royal Cappuccino Espresso Machine
When I turn on my Royal plus, the digital screen says Decalcify. What does this mean and how do I do it?
HI
To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows to scroll up until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say, "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to "Signal Descale" and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Feb 09, 2011 | Saeco Royal Digital Plus Coffee...
Hello , I got a present of a Saeco Royal Professional without an instruction booklet . The machine tells me it needs a descale . Can you please advise as to how . Many thanks , Sean Kavanagh
Hi
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the steam knob then open it again to rinse your machine. When its done exit the descale mode and go to the "Reset descale" just under it and enter. Choose "Yes" and push the enter button to accept. It will tell you when it needs to be descaled again.
If you want to make your machine last a long time, go to the water hardness in the menu and change your water hardness to the #4 and always push the enter button if you want to make your changes permanent. If you don't, no changes will be made and it will still be the same when you exit.
Jan 06, 2011 | Saeco Royal Professional Espresso Machine
How do I descale my saeco comfort coffee machine? What buttons do I press? Thanks
Hi
If you have the Magic Comfort + here are the directions.
To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Dec 29, 2010 | Saeco Magic Comfort Plus Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
How to descale machine
Hi
Sep 25, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
Where do i get a manual to de calcify a saeko royal
Hi Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix 32 oz. of water in the tank with descaling solution (1 packet or 1 oz.) and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say “Descale finished”. Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose “Yes” and push enter so the machine will tell you when you need to descale again. Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
Feb 07, 2010 | Saeco Royal Professional Espresso Machine
Hi We have misplace user guide and our machine is
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say “Descale finished”. Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose “Yes” and push enter so the machine will tell you when you need to descale again.
Nov 25, 2009 | Saeco Royal Professional Espresso Machine
Descaling
There is a software Problem on the electronic in the back of the coffee maschine.
Changing that electronic to the new version will sort that Problem.
Mr. Cool
Sep 07, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
105 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
