Question about HP LaserJet 1018 Printer
Missing catridge or door open
I bought a newn toner 12A for my laserjet printer 1018. When I put it in the printer and command a print job, a message appears that missing catridge or front door open. When I put back the previous one, the message doesn't appear and works properly. How can I solve it?
    Problem Solver:
  • 6 Answers
When you put new 12A cartridge. you have to align it trough by the option.
Posted on Feb 17, 2009
  • bobbey13 Apr 22, 2011
    i had the same error and it was simply a corner of a paper wich was folded, i removed it
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
I have a problem installing my printer (hp laserjet 1010)it gives me 0*000006ben how do i solve it?
Oct 29, 2013 | HP LaserJet 1010 Printer
I've got a HP laserjet 1012. I have placed a new print cartridge 12A black, but my computer still give the message "toner empty" and my printer have still the flashing red light. What i have...
I wont think so that there is no toner level sensing in 12a catridge, messaige might be catridge missing or incert catridge.. remove back door see down right side sensor which sensing the catridge presence, check sensor flag dislocate/spring dislocate/broken correct it, if sensor is dusty clean it... Best of luck
Sep 09, 2011 | HP LaserJet 1012 Printer
The HP Laserjet 1018 has the front cover door open or the toner is missing
You need to perform following steps:-
Open the door of toner and close it properly
take out the toner cartridge and insert as directed in manual
clean the electric contacts of cartridge and printer
otherwise you need technical assistance for repair
Good Luck
Jan 31, 2011 | HP LaserJet 1018 Printer
Black line going down side of paper from HP laserjet 1018
Roller Drum Problem in the cartridge.
If you are printing bulky document it may damage the roller drum causing dark line starting for both left and right paper. It will get bigger once it span of time.
Or if you are refilling the toner of the catridge, the waste compartment is full and requires to remove the waste tones inside the cartridge.
Or the worst thing is the the FUSER FILM ROLLER (orange plastic roller inside the printer is torn or burn because of heat or bulky printing.
Dec 08, 2010 | HP Hewlett Packard LaserJet 1018 Printer
Hp Laserjet 1018
change the cartridge and try it
Feb 24, 2009 | HP LaserJet 1018 Printer
My HP laserjet 1018 doesn't work
first of all remove the power cable and rmove the usb connection or  parallal connection from the pc. Then conneted the power and usb cable. you need to open the case to remove the printer cartise. and add the cartise. Start your pc. give print command.
Jan 23, 2009 | HP Hewlett Packard LaserJet 1018 Printer
Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
May 28, 2008 | HP LaserJet 1018 Printer
565 people viewed this question
Ben Johnson
