Question about MSI K9VGM-V Motherboard
RAM comapatibility issue
Currently working with Kingston 1gb ddr2 667 value RAM. i am trying to add a Transcend 1gb ddr2 667 RAM but system would not run if both of them are installed at the same time. Tried resetting bios setting, it would read both but after the save and close screen system freezes.
  • motegp Feb 17, 2009
    Yep, I tried running both RAMS individually and they are OK - I even tried resetting BIOS after installing both at the same time -
    RESULT: BIOS ABLE TO READ BOTH RAMS
    BUT:
    when you save and close - system restart - it freezes :(
  • 51 Answers
As long as the RAM speeds/specs are the same, this should not be an issue. The most likely culprit here is faulty RAM :(
Have you tried removing the Kingston RAM completely, and trying to run off only the Transcend RAM?
If this does not work, then its almost certain that the Transcend RAM is faulty. If it does work, then the issue must lie elsewhere.
Posted on Feb 17, 2009
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Hi, what RAM can I or can't I add on my GA-8I945PM ?
No, *********** board only supports DDR2 Ram thus the PC2 in your current RAM. Also the maximum capacity of your motherboard is 4gb. So if I were you I would recommend going to 4 1gb PC2-4200 modules. This would reduce latency as opposed to 2 2gb sticks. Also I recommend the 4200 rather than the 6400 or anything else as that is the optimal speed for your motherboard. Kingston is a good company to buy from, I am currently using 8 Kingston FB 2gb DDR3 sticks in my MAC Pro.
Mar 29, 2012 | Computers & Internet
Can i use ddr2 kvr800 for my pc
Product Details Kingston DDR2 800 2G Memory Ram 1).Capacity :512MB.1GB.2GB 2).Model:KVR800D2S6/2G 3).Interface :DDR2 SODIMM computer ram,memory ram,laptop ddr ram,memory module Product Description User Rating: 0.0/5 Kingston Technology Kingston ValueRAM Computer RAM 2 GB - of DDR2 SDRAM, KVR800D2S62G KVR-800D2S62G KVR800-D2S62G KVR-800-D2S62G KVR800D-2S62G KVR-800D-2S62G KVR800-D-2S62G KVR-800-D-2S62G KVR800D2-S62G KVR-800D2-S62G KVR800-D2-S62G KVR-800-D2-S62G KVR800D-2-S62G KVR-800D-, ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices. Product SpecificationsModelBrandKingstonModelKVR800D2S6/2GType200-Pin DDR2 SO-DIMM
Apr 03, 2011 | Computers & Internet
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
Sep 02, 2009 | Computers & Internet
I want to add RAM to my hp pavilion dv4269us. how do i know how many cards i can add? i want at least 1GB or 2. Is there room for two 1GB cards or room for one 2GB card? What are the best brands? and...
Hi there.
Your system supports 2 GIG (1x GIG each slot)
Have a look here >>>>>>
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=90110
Kingston is one of the best memory modules you can get.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Pavilion dv4000 Notebook
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
Want to upgrade ram to 1gb
Kingston Value Ram will do, nothing over 533mhz
regards
Nov 24, 2008 | EliteGroup P4M800-M7 Motherboard
KINGSTON VALUE RAM 1GB PC3200 MEMORY
You have the answer in your question. I have checked the PC specification and you are right, it uses PC2700 memory. Therefore you need to install PC2700 memory. PC3200 memory will be the wrong speed and will not be supported.
Daryl
Apr 18, 2008 | Computers & Internet
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
MSI K9VGM-V Motherboard Logo
195 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
