Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Cutting crooked homelite 16in. When making a cut the saw bar seems to wander to the right when cutting a log and this makes the bar some times bind. Can the bar be fixed or do I need a new one?
    Problem Solver:
  • 16 Answers
Usually when this happends it's the chain and not the bar. I would take the chain to someone or someplace that has a Electric Bench Sharpener, This will re-true your chain to cut even and straight again. On the "Down-Side" of this, Sometimes they tend to take alttle too make off of the chain which shortens the life of the Chain. But in Your case that may be the only way to get it back on Track. Hope this helps You!
Posted on Feb 17, 2009
  • 4,234 Answers
The chain is not sharpened evenly. One side is cutting faster than the other. Also check to be sure that the bar itself is not worn excessively on one side. The cheapest way to test this is to change the chain.
Dan
Have a homelite gas chainsaw it will start and idle but can' t seem to figure out why the chain won't turn. is there a button of lever to hold to turn the chain to cut?
The saw has a centrifical clutch that engages as rpm's rise. Some saws have a safety brake. It could be stuck. With the saw off can you move the chain by hand? When you rev the saw does it sound labored? The groove in the bar might be obstructed making the chain hang up. If it revs freely but the chain doesn't move, your clutch could be worn. .
May 28, 2014 | Air Tools & Compressors
Chain binds on bar when trying to cut and will not move. If it runs very long the clutch gets hot. Why is it binding?
Have you been putting oil in the lube tank? If you have, and have been making sure it's using it, then the chain has a bent guide, or the guide in the bar has been bent, or the chain is too tight. They're pretty simple machines. The possibilities are fairly limited.
Jul 06, 2011 | Homelite ZR10926 16" Chain Saw
The saw is a 385xp. We have changed bars and chains numerous times. When sawing the bar gets hot enough to fry an egg and the chain stretches out. Onlynable to saw a minute or teo at the time. bar gets...
Overheating the chain/bar is usually caused by insufficient oil getting to the chain, but can be caused by the chain being too tight to begin with (you should be able to turn the chain by hand), grit in the chain groove, or a poorly sharpened chain. The saw has an oil volume adjustment screw on the lower part of the case near the chain return area. Turning it CCW should increase oil flow. Oil volume can be judged by running the saw tip at speed near some cardboard for a moment--it should throw off a thin line of oil. Chain sharpening condition can be judged by the sawdust residue coming from the cut--if a powder-like material, the teeth are not sharp or are improperly filed. You should not have to bear down excessively on the saw to make it cut quickly. Hope some of this helps!
Jan 09, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain saw starts fine, idles fine, and powers up fine when not cutting a long how when starting to cut a log it bogs down and dies. Does anyone know how to fix this problem or what’s wrong with the chain...
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Sep 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw isn't cutting straight
The odds of a bent a bar approach winning the lottery, while possible it is not likely! ALL the teeth must be of equal and opposite angles. I think a new or professionally sharpened chain will cut true.
Pretty good quick video. There are many that are not worth watching.
http://www.5min.com/Video/Tree-Cutting-Safety-Chainsaw-Sharpening-15094965
By Oregon and very comprehensive. I suggest you read everything that looks remotely connected.
http://www.oregonchain.com/pro/service/faq.htm
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | Husqvarna Forest & Garden #966906636 445...
When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
This is difficult to describe but plan your cuts and test it out.
Cheers,
Kevin
Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The blade cuts part way through a log and then goes side ways. I took it off to see if it had a bend or something with the bar but the bar is straight and does not seem bent.
replace the bar - evidently one side of the bar is worn more that the other part of the rail. the chain twists and runs crooked onthe bar.
Oct 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
169 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
