Question about Freestyle Cycling
How do I reassemble crank on a GT mountain bike?
I'm trying to put together the crank on a GT XCR 3000 womens mountain bike. Unfortunately I didn't see it when it was together so I'm not sure how to do it. Any help is greatly appreciated.
    New Friend:
  • 77 Answers
First you need to know that you have all the parts needed to put it on. The List: --Both left and right crankarms (right side has the gears)
--Axle installed into the frame (no? take it to a bike shop... specialty tooling is required to put them on and there is no way to fudge around it with general tools found in most homes)
-- Two nuts or bolts that thread easily into the axle ( check that they do by threading them in by hand)
-- A ratchet handle and thin wall 14mm socket
Hook the chain onto the smallest gear and slide it onto the axle arm until it stops, give it a light tap with your hand to make sure that it's stuck on, thread on the nut or bolt that fit onto the axle and thread it on until it touches the arm (already on).
Sit the bike upside down, or on a stand so that the crankarm can swing freely in the air. Now take the other arm and put it on with the pedal at the top, facing away from the frame, tap it on with your hand and thread the other nut or bolt on with your free hand.
Grab the ratchet and tighten both nuts with enough force to ensure that they won't come off ( try picking up a 50lb bag of something with one hand as an example of the amount of force needed, that should be enough force to keep them on).
Carefully take it out for a test ride then come back and let us know how you did!
Posted on Feb 19, 2009
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
How do i adjust mountain bike brakes
There is a small tension nut on the cable near the brake calipers on the cable coming from the brake. Loosen that nut and squeeze or loosen the brakes to where you want them and then retighten the nut on the cable.
Sep 08, 2012 | Magna Women-s 28 In Cityscape Bike
I have 26" Mongoose Snarl,both
A simple web search for 'remove bicycle crank' turns up numerous videos. has the many special tools and advice one needs to work on a bike.
Aug 21, 2011 | Mongoose Sector 26 Men's Full Suspension...
I Have a Magna Mountain tamer 15 speed bike and i need the manual for it.
i need an owners manual for a Magna Mountain tamer bike a 15 speed womens
May 28, 2011 | Cycling
Crank removal for new bearings
Everything you need to know by the makers of the tools you need to own...
...unless you just take it down to a Local Bike Shop.
May 31, 2010 | Diamondback Lustre Two Women's Mountain...
Frontier GSX Women's Mountain Bike: what is proper way to remove and re-install the qu...
Unhook the front brake, loose the quick release level and push the tire off the fork. reverse procedure to install.
May 16, 2010 | Schwinn Frontier GSX Women's Mountain Bike
We have 2 regular bicycles. We would like to put
Just about any decent bike shop should sell them. Just had a look on Google for "exercise bike stand" and got hundreds of hits..
Oct 06, 2009 | Huffy Womens Mountain Bike - Blue/Grey
Cycling Logo
359 people viewed this question
Top Freestyle Cycling Experts
Michial Gueffroy
Rommel Balcita
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a Freestyle Cycling Expert? Answer questions, earn points and help others
