Question about Ryobi Garden
Ryobi PBV-30A Carb problem
I havve a Ryobi PBV-30A two stroke blower vac.which runs ok on idle but very rough at speed. Orientation of the blower in use seems to affect the speed from very rough to better but not good.
The only apparent adjustment is the throttle stop screw for idle speed adjustment. I have disassembled the carb and cleaned (although it all looked ok) and refitted to no avail.
A new spark plug has been fitted.
Can anyone offer advice.
thanks
Sell it as quick as you can..piece of s*#t !
Posted on Jan 03, 2015
I have a rayobi PBV30A petrol trimmer and it keeps dying once you increase the throttle speed runs on idle.
Posted on Sep 04, 2011
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
My 99 454 3500 chevy ou runs rough at idle but runs fine at higher rpm:s
wow a 99 an oldie but a goodie , one that old id be looking at all the vac lines , for pin holes,worn spots and cracks , a vac leak will make engne run rough at idle and as you acclerate the vac goes away so hole in hose does not matter
Sep 11, 2014 | Chevrolet Cars & Trucks
Why does a leaf blower keep stalling after a period of use?
Ignition coil may be getting too toasty. Full throttle for 10 minutes.. yeah man no one does that. If factory calls for 50:1 gas/oil mix then richen it up to 40:1
Aug 21, 2013 | Poulan Garden
Factory H+L neadle setting fo ryobi blwr/vac#ry08554/ry09907
Many small carburator needles have plastic caps on them to limit how far they can be adjusted. If you need to go past their limited settings you'll have to break those caps off if you have them. Turn both the L and H needles in just to where they seat, not tight, then turn them out one full turn. Start the blower and let it warm up to operating temperature. With the motor idling, if necessary turn the L needle in or out to where it is idling smoothly. Turn it in until you notice the idle speed change or it starts running rough. Now turn it out, counting the turns, until you go past smooth idle and get to where it gets rough again. Turn it back in halfway and you're good on the L idle needle. For the H needle, hold the throttle at 3/4 full throttle and do the same thing to adjust the needle to half way between the rough running points.
Mar 11, 2012 | Ryobi Garden
What are the settings and which jet is high speed adjustment for Homelite Inc. vac attack blower EM08652-01
Hi Roseann, newer 2 stroke engines for the past 6 or 7 years have changed to newer carburetors, and some of them don't have any adjustment needles at all, or just 1 adjustment needle adjust. Without knowing how old your Homelite is or what type of carb you have, I will assume you have adjustments. If you look carefully at your carb, next to each needle you will find the letters F or H, F is the fast speed adjust needle and L is the low one. In general the L or low speed needle is the one closest to the motor. To adjust them you turn both the H and L needles in (clockwise) until lightly seated (so no damage is done to the needle or the seat), now you turn them both out (counterclockwise) 1 turn. You should be able to start your vac with these settings. Only minor adjustments should be required if any at all. To adjust the low one with your engine running at idle, turn in just a little and notice if any difference, if not turn a little bit more until it starts to run rough, now bring back to the position you started with and now turn it out (counterclockwise) in small turns at a time until it starts to run rough. When you do this remember the position of the needle (how far in and how far out) and adjust to the needle to the middle of those 2 positions. Do the same with the H or high needle. At the top of the carb where the throttle cable hooks to the carb you will find a screw that is to adjust the idle speed by adjusting the throttle position. You can adjust that screw at any time to get the idle speed you want.
I hope this is a bit helpful to you. All the best and good luck. Any questions welcome.
Feb 23, 2011 | Garden
I have a Ryobi PBV-30A Blower and require a diaphragm kit. It is fitted with a Walbro carb, however, I cannot tell which model of carb. Can you tell me the Walbro model number/type? Thanks Marc
If you clean the dirt off the carb, the series no. and model no. will be etched into the body of the carb by the fuel inlet nozzel.
Feb 09, 2011 | Ryobi Garden
Ryobi pbv-30a will not start this blower was used about six times but is now out of warranty has a strong spark but will make no effort to start
Hi, Make sure your fuel /oil mix is correct, then, take a capfull of fuel and pour a few drops down the cylinder. After replacing the plug, give the starter a try. With fuel in the chamber and a confirmed spark, the engine has no choice but to fire. From here, you can determine if the idle adjustment needs to be changed. Hope this helps.
Dec 04, 2010 | Ryobi Garden
Garden Logo
1,958 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
