Question about HP LaserJet 1022 Printer
I got the error '' Unable to connect the printer , access denied , printer could not be started'' . I have a XP home m/c to which i have connected HP 1022 printer. I have shared it with all machines in the LAN. On the host m/c printer working fine. but from the workgroup pc it shows ''Unable to connect''. Then i have to restart the host PC everytime, Then it works fine for max half an hour. repeat the issue. and same process again. Any smart answer will definitely help me out. Pls Help me?
    Problem Solver:
  • 7 Answers
Are you on the same network as the host machine. In simple terms, the machine that you are trying to printer should be on the same network/domain.
click on start, right click on my computer and go to properties. Under properties check the computer name tab. specifically the workgroup. see if that matches the host machine. If it's different that's the issue.
If its different click on the button change, and type the domain in the box below.
hope this helps.
Posted on Feb 17, 2009
I share hp laserjet 1020 printer but when i shut down after start pc printer not access & unable to connect or access denied display occured on other pcs, what i do?
When you share the printer that is connected to your computer for other computers to use this printer, your computer MUST be left on at all times for the other computers to print to this printer.
The reason is, your computer acts as a print server, it collects the print data from the other computers and sends it to the printer.
Jul 10, 2011 | HP LaserJet 1020 Printer
Network Connection Always Shows Access Denied
If you are always getting Access Denied errors when trying to connect to a XP computer,
and you know you have the correct user names and passwords on the computer,
the solution may be a simple registry edit.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlSet / Control / Lsa
  3. Change the value of a key called "restrictanonymous" to 0 instead of 1
  4. Don't change "restrictanonymoussam" value.
  5. Reboot
on Sep 20, 2010 | Computers & Internet
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
I am trying to access an HP 1200 psc over a home network
Have you set up the printer to be shared via the network? You can usually set this up in printer options, through control panel. If the wifi is a closed network, so much the better. That way, nobody else can use the printer. You should be able to do this easily, as long as both computers are connected to the wireless network.
Oct 22, 2009 | HP PSC 1210v All-In-One InkJet Printer
Print from vista to xp with usb connected lexmark 2350 results in access denied error after timeout. Vista access shared printer through a wireless router. Any recommendations?
Okay, I need to understand your topology a little better. You have two PCs, one using Vista and one using XP. Both PCs are connected to the Wireless modem. The printer is connected to the XP PC and shared across the local network? When the Vista unit sends a job to the printer, you get an access error message. Is this description accurate? Normally this would be caused by the sharing settings on the XP unit. Please make sure you have the sharing options correctly set on the XP unit and then get back to me if I've given you an incorrect path to follow. Don
Jun 06, 2009 | Lexmark X2500 All-In-One Printer
E: Access Denied when I connected a Flas Drive on a HP DC 5000
if you contact the manufacturer of the flash drive they may have a reset program for it.. I had a similar problem with a flash drive that I had configred as a key to lock my pc.. but I forgot the password and the flashdrive was then worthless even the reset prog couildn't help it :( hate to be the devils advocate but you may have to replace the flassh drive
May 18, 2009 | Computers & Internet
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Unable to share printer
You need to go into the machine that manages the printer and allow the access denied machine access or to share printer. You may have to run the network setup wizard in order for the machines to recognize each other.
Jun 23, 2008 | Dell Inspiron 1501 Notebook
HP LaserJet 1022 Printer Logo
339 people viewed this question
Ben Johnson
