Question about Epson Stylus D88 InkJet Photo Printer
Acer Aspire 5610z laptop lcd picture breaking up and going blank
My Acer Aspire 5610z laptop lcd picture is breaking up and going blank after switch on.
I have changed the lcd inverter board and power leads but this has not solved the problem.
It has been possible to gain a picture (with difficulty) by going through makeshift procedures. The makeshift procedures were more effective, the longer the laptop was switched on (when the circuitry has warmed up).
1. When the problem first started happening, swinging the screen back and forth brought back the picture. This has become less effective.
2. The next thing I tried was removing the battery and starting the laptop on its mains supply.
This resulted in the picture coming on for a short period when cold.
3. I removed and inserted the mains supply repeatedly until the picture stayed on.
The picture stayed on for longer but still went off during the desktop loading period.
4. I then went through procedure 3. again and this time inserted the battery when the desktop started loading.
This resulted in the picture staying on for an hour or more but eventually going off again.
All of the above symtoms and procedures had been happening and tried when I used my laptop on my lap.
5. I moved my laptop onto a table with the power supply transformer next to it so there was no possibility of movement.
This resulted in a broken picture for a one or two seconds before going off.
I pulled out the mains supply and reinserted it and switched the laptop on. This resulted in the picture staying on for as long as the power supply was connected.
I understand that the above makeshift procedures are a temporary measure for me, until I find the correct solution.
The symptoms above remind me of intermittant faults caused by dry joints or components on their way out.
I suspect that a voltage that enables the lcd picture, is being impeded by poor conductivity of solder joints or components. The use of the mains supply appears to provide a voltage surge that overcomes obstacle to initiating the picture. The stability provided by the table and inserting the battery appears to provide the voltage stability necessary for maintaining the picture.
As I have said above this is only a tempory measure for me, can anybody please provide the correct solution?
  • 14 Answers
SOURCE: Toner fitted incorrectly
hi jeff, this is a minor repeatable bug yet a great nuisance that will be fully fixed by good house keeping. Simple ABC...
1. Remove All the toners
2. with a spotlight have a look at the far end of the toner cartridge holder drum, i.e peep through the hole left blank after removing the toners.: go through one to the other whilst brushing off dust with a long paint brush. Pay particular attention to the springy looking metal parts deep at the end. (responsible for sensing the toners)
3. On all the toners themselves wipe clean all the metallic parts
this should sought you out 100%
However if you fail or rather you want an overhaul - remove the toners,photoconductor and transferunit. then give your printer a serious blow using the ordinary blower.
Posted on May 22, 2008
  • 16 Answers
SOURCE: Head carriage stays left and grinds
Did you check to see if the ink was low in the printer? Epson wont let you print if the ink is low, happened to me before!
Posted on Oct 22, 2008
  • 9 Answers
SOURCE: Printer shows a paper jam when there does not appear to be one
Often, even after you have removed the paper jam, one of the sensors can still report a "Paper Jam". These sensors look like small plastic "fingers" that project along paper path. More sophisticated printers may have an "electric eye" mechanism. Sometimes when you get a bad jam, the paper has to be ripped out, and a very small piece can get caught on one of the sensors or block the electric eye type sensor. Remove the ink cartridges and shine a light into the machine and look for small pieces of paper stuck inside, and gently remove them. If one of the sensor fingers is bent or jammed, it can cause the same problem. See if any of these are stuck and gently free them. Take care, since they break off very easily. They may also break off if you forcibly pull out a jammed paper. If one of the sensors is broken, then you are out of luck, and will need to buy a new printer. you can also try vaccuming insides with one of those flat nozzles connnected to a regular vaccum cleaner.
Posted on May 13, 2009
SOURCE: error massage not compatible ink cartrage when using ciss supply
The problem here is that Epson actually programs the hardware to recognise if you are not using genuine ink cartridges and the malfunctions you are experiencing are programmed malfunctions, they are not random faults. The .PIF file on the install disk is indeed infected with spector keylogger although after being contacted, epson denies this is true. Spector is very hard to find and was designed to remain hidden at all cost and is the height of keylogger technology even to this day.
Sadly, several versions of epsons' printer/scanners are infected and it appears to be everything made after 2005.
The net is rife with the known problems of epson ink whick appears to be the cheapest on the market but the usuage percentage is in reality much higher than other printers.
My advice is not to buy Epson products, they are unreliable and unsafe.
Posted on Oct 08, 2009
SOURCE: newly purchased TX550W works through USB cable
use the netsetup utility to setup wifi settings. it works well. but wont scan on wifi. the utility hangs
Posted on Feb 16, 2010
Aspire 5610z lcd light no working
if you can shine a flash light on the screen and see the picture then there are 2 possibilities 1. bad back light 2. bad inverter (unless it is a led back light) both parts are not to expensive on eBay (search for your model #) the tough part is installing them, if you never have taken a laptop apart you may not want to try, if you do.... take lots of pictures and use a piece of card board to **** the screws into in the position you removed them to help remember were they go.
Sep 29, 2011 | Acer Aspire 5610-4648 Notebook
I cant play any dvd -rom on my acer aspire 5610z
This is a problem with the Drivers. Go to acers website and download the drivers for your DVD rom drive
Mar 04, 2011 | Acer ASPIRE 5610Z2273 COMPATIBLE LAPTOP...
My Acer Aspire 5610Z crashed last Nov, a month after I had it a year, since then the webcam (built in) will work with msn ect, but I can no loner access it to take pictures and save them, nor can I find...
This is the support site for your laptop, Click on the link > click notebook > click Aspire > scroll down to the 5610z > download the application and drivers for the crystal eye web cam. Run programs and install.
Sep 15, 2009 | Acer Aspire 5610-4648 Notebook
Acer aspire 5610z blank screen after power up...
Is it a black screen with a cursor?
turn on the monitor.
Jul 13, 2009 | Acer Aspire 5610-4648 Notebook
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
My laptop will not come on. it will power up but then nothing els
i just fixed the same problem - it's very well known -on my aspire one. the fix was updating the bios via a USB - here's one link: but make sure it's right for your own system. good luck
Mar 16, 2009 | Acer Aspire 5610-4648 Notebook
My Acer Aspire 5610z laptop picture is breaking up + going blank
Replace the screen, you can download the pixel tester softwar to figure out if the screen is going bad. I'm pretty sure it is.
If you change the inverter its either the onboard video card on your laptop (usually not replaceable easily) or the screen.
Feb 18, 2009 | Acer Computers & Internet
Help with burning off my home made dvd on my laptop Acer Aspire 5610z
Mar 07, 2008 | Acer Aspire 5610 Notebook
Epson Stylus D88 InkJet Photo Printer Logo
124 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
