Question about Marantz Audio Players & Recorders
No blue face lite
Vintage Model 1040 amplifer works wonderfully ,but only power lites on blue face. Is this a bulb that I could replce?
  • 4,234 Answers
I am not familiar with your particular model, but Marantz used different bulb styles in different models. Some use fuise style others use soldered in types. You should be able to see the bulb type by removing the top cover. I'll research this a bit and update this.
Dan
Posted on Feb 17, 2009
My right front turn signal on my 1997 fordf250 truck will come on but will not blink. I have replaced the bulb and bulb socket but it did not help. What could be my problem?
The other turn signals front and rear work ok? Disconnect right turn signal, with that signal turned on, use a test lite on the white wire with lite blue tracer, does the test lite pulse?
Does the right turn indicator on the dash pulse on and off?
May 26, 2017 | Cars & Trucks
Brakelight not working, tail running light works but not brake light, have replaced bulb and rear brake switch, no luck. XL1200L sportster. Is there a circuit breaker??? Where ?
there is a break pressure switch on the brake line with 2 wires plugged into it -- replace the switch and your brake light will work
Mar 17, 2015 | Harley Davidson Motorcycles
Light bulb icon lite up blue and black screen
Remove main battery and power up, no change! sub out the memory ram one at a time and test each piece, if still no change! laptop will need to be checked.
Apr 10, 2012 | Acer Aspire 1200X Notebook
Nintendo ds lite help
Maybe the battery is defective. try to replace it.
Jun 29, 2010 | Nintendo DS Lite Console
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Brake lights will not work.
check all your fuses if fuses are good check brake lite bulbs see if they are blown. if bulbs are good get a test lite see if you have power to the bulb sockets have friend apply brake pedal you test power going into bulb socket if you have no power brake lite switch behind brake pedal could be burnt out. p.s dont forget to check all fese relays when checking your fuses.
Apr 26, 2010 | 2006 Chevrolet Colorado
60 in sony grand wega
if it turns to red most likely you need to replace the bulb.
Larry D
Aug 15, 2009 | Televison & Video
Ford E-150 brake lights
I don't know the model year, to look up wiring diagram? Do you have a high mount brake lite? Does it work? The highmount and lower brake lites are routed differently, the lower brake lites are usually routed through the multifunction switch, the highmount brake lite isn't wired that way. Did you check voltage at brake switch for brake lites, that is a fused circuit.
Usually the lower brake lites and turn use the same bulb filament, but, not at the same time.
Nov 22, 2017 | Ford E-150 Cars & Trucks
Colors all off blue screen is lite brown
this happened with my friends tv, i dont really know the model of yours but he fixed his by replacing the light bulb that lights the lcd screen.  dunno if thats any help, but if you cant figure it out contact customer sopport
Oct 17, 2007 | Olevia LT27HVX 27 in. LCD Television
82 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
