Question about HP LaserJet 4345mfp Printer
49 2f81- error
What can be done to resolve this issues of error
    Problem Solver:
  • 6 Answers
Replace the hard drive. Reintialize new hard drive and load latest version of firmware.
Posted on Sep 09, 2010
    President:
  • HP Master
  • 1,314 Answers
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
Posted on Feb 17, 2009
Lens will not extend, gets LENS error
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Canon PowerShot G5 Digital Camera
Lens error
Hi
Thanks
Rylee
Sep 15, 2010 | Nikon Coolpix S210 Digital Camera
Lens error 20e, 0, 0,0
Hi
Thanks for using FixYa. To start with keep turning it on/off, if still not resolved then try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that’s stuck in there. If still the issue is not resolved then you’ll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Kodak Easyshare C813 Digital Camera
HTTP 501 ERROR
To resolve this issue:
  1. In Internet Explorer, click Internet Options on the Tools menu.
  2. In the Internet Options dialog box, click the Advanced tab.
  3. Click to clear the HTTP 1.1 check box, and then click OK.
  4. Test to determine if the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
  5. In Internet Explorer, click Internet Options on the Tools menu.
  6. In the Internet Options dialog box, click the Advanced tab.
  7. Click to clear the Show friendly HTTP error messages check box.
  8. Try to view a Web page to reproduce the error message and to receive a new, more descriptive error message. This new error message may be similar to the following: HTTP version not supported by program name. Note the name of the program in this new error message.
  9. The program name that you noted in step 8 may be the cause of this issue. Either remove this program, or reinstall it.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | Computers & Internet
I have a 60.2 printer error on my HP printer. It
For further resolution abt this error u can follow the forum ::
http://www.laserquipt.com/support/idx/62/325/article/-602-603-or-604-Error.html
I hope it will resolve ur Issue
Apr 07, 2010 | HP LaserJet 4200 Printer
Error Code: 8001050F - PSN Issues
I have been on the phone with the PSN and they said they are having mantanice done on there end. There original ETA was 9pm EST but has now been moved to 10pm. Just be patient.
Rented Movies, Trophys, Games will also have an affect with this issue until its resolved.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
My printer is not printing
Hi
Hope your new year is going good and hoping the best for next
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.The Problem which you mentioned is not complete error due to which its difficult to give you the straight solution
I am provided you with few Links for solving tour issue
According to your Problem select the link below
Problem 1) Windows XP: 'Printer is offline' Message Displays on the Computer and the USB Connected All-in-One Will Not Print
Problem 2)Can't Print: Guide to Finding Solutions and Answers to Printing Problems I think this will solve your issue
If Issue resolved Please Vote me
To resolve the issue, unfortunately i require additional information. Note that the more specific the details you provide, the better our ability to resolve the issue quickly. Please provide the following information:
  • Let me know exactly what you do, step-by-step, and where the process fails.
  • When did the problem first begin?
  • Does an error message occur? If yes, provide the exact error message and the steps that trigger it.
  • Have you done any initial troubleshooting? If yes, provide details about the steps you've taken
As you work through the article or Links , please note the result of each step, including any error messages you receive. If you require further assistance, please update your information with these details. The more specific the details you provide, the better our ability to resolve the issue quickly.
Cheers
Tejodhar Atreya
tejodhar.atreya@gmail.com
Jan 04, 2010 | HP DeskJet F380 All-In-One Printer
Error:0xo0620004411:lib_miooi2.o
1. Disconnect the power cable from power source without turning of the unit.
2. Press and hold Ok and Cancel while plugging in the power cord directly into wall outlet.
3. It should resolve your issue.
Aug 27, 2009 | HP Officejet 7210 All-In-One InkJet...
Ink system failure
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much. adonscott
Jul 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error 0280
Replace the CMOS battery and reset the BIOS to default settings. This will resolve the issue.
Jan 27, 2008 | Hitachi DZ-MV730A DVD Camcorder
915 people viewed this question
Ben Johnson
