Question about Electric Air Tools & Compressors
Engine does not restart to build up more air
Compressor was working. Air dropped to almost zero but engine will not restart. Switching off power does not make any difference. Bottom of electric motor is very hot.
  • 4,234 Answers
I would guess that the motor is overheating and the thermal cutoff is kicking in. Once the unit cools down, it will probably run again.
Check the motor for oil etc. You will need to determine why the motor is getting hot.
Dan
Posted on Feb 20, 2009
I have a LeRoy older model pull-behind air compressor. When it starts up it low idles but shuts off before it builds pressure. I have all the valves open I have low in pressure but the motor keeps dying. I...
I'm not familiar with that model air compressor, I'm assuming this is a rotary screw driven by a gas or Diesel engine? If the inlet valve is open & the air compressor is attempting to compress air while the engine is starting up, it can be too large of a load for the engine to continue running. I would be checking to make sure I followed all the steps of the mfg start up procedure. If you had a reciprocating air compressor driven by an electric motor and the check valve or unloader valve fails and there is air pressure coming backwards thru the piping against the valves, the actual compressor itself becomes too hard for the electric motor to turn over. The amp draw is so large it causes the breaker to trip. In your case you probably don't have any back pressure coming from other machines making it hard to start but if the inlet valve on the air end is open it could have the same effect. If there is zero pressure in the machine and you start the engine. Everything is going to rotate. The inlet valve for the compressor has to be shut somehow to prevent the compressor from compressing air. If it's open, air will be drawn into the air end, the more the engine runs the more the air end will compress the air. As the internal pressure rises, the air end becomes harder and harder to turn which causes the engine to strain. That's a complete shot in the dark. There are many ways air compressors are controlled. There are many types of air compressors. It could be a problem with the engine itself. The bottom line is that you need to be able to know the air compressor is unloaded and not trying to compress air. If it is unloaded the engine should start up and run.
Dec 16, 2017 | Air Tools & Compressors
My compressor only builds 100# of pressure...it is adjusted all the way in and still only builds that pressure
Check for air leaks or possibly the filter needs cleaning. Also make sure the tank is not partially full of water. The engine may not be generating enough power because of wear. Please Read the following for more info.
Air Compressor Trouble Shooting Guide
Mar 25, 2016 | Air Tools & Compressors
When i turn on my heat/air on defrost or auto my rpms go up... what could cause this
The basic concept is that in auto or defrost the air conditioner compressor is activated.
The compressor when activated via an electrical clutch adds an additional load that will reduce the engine RPM. The the RPM is increased slightly when the A/C is activated to prevent the engine from stalling. Power produced by the engine is increased by allowing more air and gas into the engine. When it is working perfectly the RPM will remain the same but the engine will produce the additional power to power the AC compressor.
Usually the bi-pass air valve is how the compensation for the additional power is accomplished.
Depending on your make year and model several methods to achieve the AC compensations have been used. In your specific case if the compressor is not working(no Air) and the compensation is open loop no engine control electronics I would expect a surge in RPM. With no additional load from the AC the additional air into the engine would increase the RPM.
26106712-qb20k32l4fvb2dr3l0mnapaf-4-0.jpg On older cars there is a solenoid that has an adjustment for idle speed when the solenoid is activated. See the image above.
Hope this helps?
Feb 24, 2016 | Cars & Trucks
When air conditioner clutch engages it pulls down all vehicle voltage and belt and clutch start to slip
belt worn, loose or idler pulley weak --compressor clutch binding,moisture in system ,compressor internal damage
Jul 19, 2015 | 2000 Jeep Grand Cherokee
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
Air compressor will not restart after it builds pressure and pressure drops to 80 psi
Make sure the power cord is plugged into an adequate extension cord if one must be used. Never less than 12 gauge wire.
The start/run capacitor may need to be replaced.. If there are any ball check type valves, make sure they are not worn or sticking. they would be on the output of the compressor head itself.
Dec 13, 2011 | Hitachi EC12 Portable Electric 2hp Air...
I have a sears craftsman air compressor. It runs fine until it builds gets up to the max air pressure. It shuts off then as it should but as I use it and the air drops and it tries to restart, it barley...
Something may be wrong with the 'unloader' function in the air pressure control--it should drain air pressure within the exhaust tube from the compressor. You may also be running the unit on too small wiring (extension cord) and it is starving for power when the heavy load restart occurs. Hope this helps!
Aug 16, 2010 | Garden
My hitachi EC12 compressor starts up and fills the two tanks. When I connect my hose, the pressure in one tank drops to zero, then goes back up to about 60 psi, then very slowly builds back up to max...
how do you know one tank drops to zero unless you have a pressure gauge on both tanks sounds unlikely unless you are looking at the gauge on the pressure regulator
Nov 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Ec12 hard restart after drop in air pressure
It sounds like the air pressure assembly unit is not reading the pressure drop. some of these units have adjustments under the covers and be reset.
Aug 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
89 people viewed this question
Top Electric Air Tools & Compressors Experts
elunsford
John Trevino
Craig Butler
Craig Butler
Are you an Electric Air Tool and Compressor Expert? Answer questions, earn points and help others
