Question about HP LaserJet 1150 Printer
My hp 1150 printer is having a problem
Hai everybody my hp LJ printer 1150 is having some problem ...once i on the printer it gets initialises then all the 3 lights r glowing...
then i have pressed GO button then attention light is glowing ...may i know what is the solution for this...
  • arru123 Feb 20, 2009
    thanks for trying and keep supporting me for my further Quories....
    thank you..
I just bought a Kodax 5300 Easyshare the test page is fine, however when I print a document from a word doument the first print you can barely see the few lines then it does not print at all. What can I do to solve this problem?
Posted on Feb 17, 2009
Samsung lj 1640 not initialise andredled continiously glowing
printer ML- 1915 Paper jam........
sometime 2-3 paper coming ....
Exactly what happens?????????
please Replay ....
Regarding
sureshbabu
Dec 12, 2013 | Samsung ML-1640 Monochrome Laser Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
We need an English version user manual for the HP LJ 5200 tn printer that we have installed on board the vessel mt FPMC 18 . can you fwd us the same ASAP thanks .
Click this link (here) to download the english version user manual for Hp Lj 5200 dtn printer. The manual is pdf (portable document file) file format.
If the browser doesn't open the file so that you can view, then download it (it'll automatically begin downloading once you click the link).
In case you don't have a pdf reader, download adobe pdf reader from here (adobe pdf reader) [click the link and again click yellow "Download" button].
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | HP Office Equipment & Supplies
Wrong firmware installed in HP LJ 3050
I am very sorry to have to be the bear of bad news. Usually doing a failed firmware update (or wrong firmware version) you have to return to factory or have a local computer printer shop that deals in HP printers repair this firmware mixup. There is sometimes a firmware recovery mode that can help however You would have to contact HP and ask them how to get into firmware recovery mode.
Sorry hope this helps answer your quesiton.
Steven.
Apr 22, 2010 | Office Equipment & Supplies
I have a HP LJ P2015n. Should be on our network
As i understand your concern you have network printer which you want to setup with your network. And right now your printer is connected with the computer using a usb be cable. Thats the main reason why it is having different ip address because it don't required any ip address once you tried to connect your printer through usb cable. I can suggest you that once you connect your printer on the network and you will get the option to network setup on your printer where you can assigned static ip to you printer which is the range for your router or network device called DHCP.
I believe that will help your resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Oct 28, 2009 | HP LaserJet P2015dn Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
LJ 2840 installation on XP PRo
Check that the firewall either windows or other is not active and not allowing you to install drivers. Also if your computer is in user mode and does not have the right to install drivers login as administrator mode and install drivers through there.
Once deactivated firewall install new drivers should be OK then.
Thanks J
Jan 24, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 1150 Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
