Question about Motorola Mobility RAZR V3
VIDEO CAMERA AND CAMERA NOT WORKING
WHEN YOU PRESS THE BUTTON FOR VIDEO CAMERA OR CAMERA THE MOBILE HANGS AND TURNS TO BLACK SCREEN.
NOT ABLE TO TURN OFF AND NEED TO REMOVE BATTERY AND THEN TURN ON AGAIN.
  • tendragons10 Feb 20, 2009
    I HAVE STILL NOT TRIED IT AS THE SOFTWARE IS NOT AVAILABLE. BUT I AM SURE THESE ARE THE STEPS AS I WORK FOR HP GLOBALSOFT. I TROUBLESHOOT NOTEBOOKS AND IT IS QUITE SIMILAR. ANYWAYS THANKS A LOT FOR THE REPLY.
    Problem Solver:
  • 17 Answers
First of all flash your phone, with any supported phone, if not ok, check camra or camra strip, these things may be shot.
Posted on Feb 17, 2009
HOW CAN IT BE FIXED? CAN IT BE DONE ONLINE?
Have you tried doing a factory restore? It will wipe all the information from your phone(contacts, downloaded apps, etc) most likely this well solve your problem it sounds like the android os is not booting properly or may have a system dependent service crashing on boot causing the system to hang. With the phone off press and hold the power button and the vol down button(might be volume up button) should get you into recovery mode where you can do a factory reset.
Apr 24, 2014 | Kyocera Event Black Smartphone AA€A Virgin...
My sony camera dosn't work and i can't see anything just black screen
of course you need to check first, is it completely black screen. could be that its not even turning on.lucky if lets say beep feature was set to on . check if you press any buttons, is there any beeping sound. try to even press the playback and check if any icons will appear.or press the lcd button repeatedly and check if something will happen . if not , do power reset. take out the battery and hold the power button for 30sec. its like refreshing the memory of camera.. if still same thing. try changing batteries. camera also turns on by pressing playback button. if all ts fails, camera needs service. could be something wrong with its sensor.
Oct 24, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
How do i return my sidekick 4g to factory out of box state
Here are two suggestions and remember to backup if necessary.
T-Mobile Sidekick 4G Factory data reset:
1. On the main home screen, select menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if prompted, then confirm by selecting Erase everything (Note: If a Password was never set, it may be your last digits of the phone number or zero's)
T-Mobile Sidekick 4G Hard reset, this may help if the phone experience some hang or frozen on some applications:
1. Turn the phone's power off. Take the battery out from the device, wait a couple of seconds and reinsert it back again.
2. Now, Hold the Volume Down button
3. Then press and hold the Power button until the device turns on
4. A menu will show up like: Fastbook, Recovery, Clear Storage, and Simlock
5. Just select Clear Storage by pressing the Volume Down button
6. Then press and release the Power button
7. Select Volume Up if YES and Volume Down for NO
Once the reset process is complete, the phone will then reboot to its factory fresh state settings.
Any data including third-party applications previously stored from the HTC Sensation already wiped or deleted.
Jul 13, 2012 | Samsung Sidekick 4G T-Mobile Smartphone -...
The screen on my htc desire s has gone black and the phone wont respond
I solved this problem few times by completely opening my HTC Desire Z mobile phone and then reassembling it. Third time, I noticed that the problem is due to looseness of two, out of three, tiny screws at the "camera" button of the mobile set. Therefore, mobile set was not properly pressed and sealed at the "Camera" button and due to some protection by HTC, screen went black. Now I have used new relatively long tiny screws and the problem is solved permanently.
Jun 11, 2012 | HTC Desire S Cell Phone
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
Black screen on canon a 550
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on or off to save batteries. You would then use the optical viewfinder, just like you've been doing. To turn the screen back on, press the button once more.
Oct 11, 2009 | Canon PowerShot A550 Digital Camera
My iphone camera just shows a black screen when i touch the camera app and wont allow me to take pictures what can i do
pls see this First !! B4 reset
Straight from Apple Iphone Manual
Camera is not functioning
  1. Tap Camera, then point and shoot. Note: If you take a picture with iPhone turned sideways, it is automatically saved in landscape orientation. If you do not see Camera on the any of the multiple Home screens, check to make sure that Restrictions are not turned on by tapping Settings > General > Restrictions. If they are, set Allow Camera to ON or tap Disable Restrictions (in iPhone 2.1 software or later).
  2. If that doesn't work, clean the camera lens with the cleaning cloth that came in the box with iPhone.
Mar 27, 2009 | Apple iPhone Smartphone
Dcr-sr82 screen will not come on
Did you press the disp/batt info button? That should turn the screen back on because it sounds like the screen is still working...
Jun 25, 2008 | Sony Handycam DCR-SR82 Camcorder
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Motorola Mobility RAZR V3 Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
