Looking for "manual/guide" on how to replace a clutch on a 2005 VW Chico.
You need to empty the engine from all fluids, tehn remove air filter and other parts, mount your Golf on a bridge and remove the clutch pressure plate assembly mounted on a side of the engine.
You will need special tools to align and mount the new pressure plate, and you will need to follow a procedure to reinstall the clutch without removing the transaxle.
Replacing the clutch is not an easy task for a beginner, if you do it yourself, get the haynes manual with the complete illustrated procedure.
After replacing you will have to adjust the clutch. See CLUTCH REPLACEMENT PROCEDURES.
