Question about Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Master Phone
I have the Panasonic KX-T7630. I have what i call the master phone which has all the extension lights on etc. Unfortunately since I moved the phone to another location it has stopped showing me who is on the telephone, I cannot select an extension directly, I cannot select call back and I cannot do log in/out. Any ideas?
  • Panasonic Master
  • 2,460 Answers
Sure. It requires an Operating Manual (OM) and some programming. If you need the manual, here's a link http://public.carl.airpost.net/TDA/200_TDA_OM_06-12.pdf
On page 158 and 168 you can set up the features of the phone.
In order to do that, you'll go back to the phone that works, and press PROG and each button and write down what it says.
It will say things like EXT-102, LOG IN-100, VTR-165, etc.
If the buttons are labeled, note what it says, then move over to the phone you want to program. Press PROG, the button, then dial the codes from pages 168 forward for each function. It's not that difficult, for example, a DSS for ext 101 would be 1101 STORE, call log is 30100 STORE (or similar).
Each button changes when you press STORE and the feature will move if it has already been stored in another location. HOLD PROG backs you out of programming.
Please rate this solution or acknowledge that you have the manual if you need it as this link will be taken down when you do or by 2/23 if you don't..
Carl
Posted on Feb 17, 2009
How do I connect a background music source to Panasonic KX-T7630 phones?
The Music On Hold (MOH) is not connected on the KX-T7630 Phone but rather to the phone system. You will need to get an extension from the phone system and connect it to the KX-TVM50/200 Voice Processing System (VPS). Incoming calls are then answered by the extension connected to the VPS ... i sugest you get a Tech to help you with setup or get an online programmer to guide you on hardware setup and he does the programming for you.
May 27, 2014 | Panasonic KX-T7630 Corded Phone
How do I know which is the specific KX T7630 phone to program extension names on?
When you press PROGRAM ** on the right phone, it won't beep at you. By default, extension 101 is a programming phone. Access can be granted to any and all phones.
Carl
Jul 28, 2011 | Panasonic KX-T7630 Corded Phone
How to program so when someone is on a line, their extension is lit? Panasoic KX=T7630
You have 24 buttons that can be anything. The key is PROGRAM press the button and dial 1 + the extension and STORE or SAVE. The "1" tells it to be an extension. You press PROGRAM on an idle phone.
Carl
Feb 14, 2011 | Panasonic KX-T7630 Corded Phone
I have a panasonic KX-T7630--does anyone know how to delete a password, not change one.
Password to? The voice mail password is changed from mailbox 999. It may not be able to be deleted as passwords are defined in the voice mail programming. One of the options is to require a password no matter what, it may be x plus the mailbox (where x is a predefined digit, like 3).
Extension PIN's are set from the *799 command. *799 1 (PIN) # (PIN) # sets it, *799 0 (PIN) clears it, where PIN is any sequence of up to 10 digits. If you lost it, the sytem manager can reset it from the master phone
Feb 10, 2011 | Panasonic KX-T7630 Corded Phone
Cannot go to voice mail to check my old voice mail from PANASONIC kx-t7630
If your old phone was an extension on the system and it is a TVA voice mail product, you dial the VM access code (usually 500) and when it answers you dial #6 * and your old extension.
You now appear as you would have if you had pressed MESSAGE or dialed 500 from your old phone.
Carl
Sep 27, 2010 | Panasonic KX-T7630 Corded Phone
Hi, Expert Guy , I have some problem with Panasonic TDA100 about calling Out by co line i have 20 extension and 4 CO line , so when i need to call out , i press number 9 , it will switch to the line free ....
To call out: Go off hook press an idle CO button-- Dial outside phone number. There is no need to dial "9".
If you need a copy of the manual you can get one for free at the following link: HTTP://phone.manualsonline.com/manuals/mfg/panasonic/kx-t7630.html....Let me know if this answers your question. Master FixYa...
saailer@att.net
Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
How do i changing the time on a panasonic kx-t7630
This applies. You still have to find the master phone, and follow the instructions in this thread http://www.fixya.com/support/t3307294-time_change
Carl
Oct 26, 2009 | Panasonic KX-T7630 Corded Phone
How do I change the name display on my extensions
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Feb 12, 2009 | Panasonic KX-T7630 Corded Phone
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
Message Light
Panasonic KX-T7630 , to turn off the message light when their are no messages do the following.... go to the phone that the light is lit up....push Sp-phone.... enter *700 and the ext number.That should take care of the problem. :-)
Jan 24, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
398 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
