Question about Ariete Coffee Makers & Espresso Machines
Ariete Hollywood Cafe 325-water not coming thru coffee filter bit
When trying to make an ordinary coffee, there is no water coming through the coffee bit. I've pushed the water tank bit down so the valve is working, can hear the machine working but no water seems to come through the last bit. Do I need to replace something or have i forgotten to do something. I've had this for a few years now, but was in storage for the last 8 months...please help as i can't afford to buy a new coffee maker.
  • 69 Answers
If the line is obcluse you need to bring to a service point, if it is too expensive...drink tea...
Posted on Feb 22, 2015
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Posted on Jan 12, 2009
SOURCE: water light can't be reset
The gray magnetic float can sometimes get jammed. Check to see if it floats back up when adding water. If not, remove cap, reset magnet so it can move freely and replace cap, be sure the magnet floats to the top of its contained space when water is added. The system should then reset.
Posted on Aug 05, 2009
VtToolMan
  • 704 Answers
SOURCE: have just bought a cafe roma de luxe cofe machine
Here's an online version of the cafe roma coffee machine. The owner's manuals this company provide are known to be very skimpy in the info they provide, so don't expect much
Hope you find this very helpful and best regards!
http://www.ariete.net/libretti_pdf/mod1315.pdf
Posted on Aug 07, 2009
I have an Ariete Retro Coffee machine that is not filtering out the coffee grains properly when making a cup of coffee...
I notice that the filter get obcluse very easily, try to clean it in hot flush water and in the meantime use your hand palm with a push-and-pull movement over the edge of the filter, doing so you will see a spray of water coming out from the central little hole situated on the bottom of the filter, is the problem persist put ONLY THE FILTER, and not the handle into the dish washer, then it supposed to work. In certain case it is possible than the problem remain, try as a last chance to put some salt into the filter and thight the handle into the coffee machine, warm up and start the pump(do not put coffee, only salt) it works!
Feb 04, 2014 | Ariete Cafe Retro Espresso Machine
Coffee holder cup blocked
The same just happened to me, thus, looking for a replacement filterholder.
Jun 12, 2013 | Ariete Cafe Retro Espresso Machine
I am looking for a hot water element for an Ariete Coffee machine cafe roma?
go to http://www.arietegroup.com/en/assistance on the internet and type in your request with the exact model name.
Sep 21, 2012 | Ariete Coffee Makers & Espresso Machines
The pump makes all the right noises but no water comes out just a bit of stream?
somewhere ther is an obstruction and water does not come out, bring to service, do not attempt to fix yourself or can occour bigger damages.
Sep 12, 2011 | Ariete Cafe Retro Espresso Machine
Have just bought a cafe roma de luxe cofe machine
Aug 07, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
268 people viewed this question
Top Ariete Coffee Makers & Espresso Machines Experts
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Ariete Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
