Question about Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater...
Easiboost power shower - problem
I have an easi boost power shower. it is about 18 months old. last couple of weeks if i turn hot tap on upstairs or downstairs -when i turn the tap off the shower pump fires up for about a second or two. i have no idea why its doing this but its driving me mad. any ideas how to cure it - the shower is fine otherwise
  • 332 Answers
It comes on when the pressure changes so when you open another faucet it changes the pressure and makes it come on,, check your pressure regulator valve on the main line comming into the house it has a screw in the center, if you have a pressue gage put it on either the water heater drain or out side hose bib , check the pressure when turning water on and off if it changes more then 5 lbs you need to change your prv valve. pressure regulator valve,
Posted on Jun 06, 2009
Why when I turn the hot taps on I get milky water out of the hot taps and its a new HWS Vulcan 250 lit electric single element only 3 months old
Put that water in a glass and let it sit for a couple of hours. If it clears up, it is air bubbles. The old unit most likely had mineral deposits on the elements and they insulated the water from micro heating that creates the bubble. Since the unit is new, the water is in direct contact with the heating elements and micro bubbles are forming on the elements. When you turn the hot water on, the turbulence washes the bubbles out.
Sep 04, 2016 | Water Water Heaters
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
Bosch water heater keeps getting error EA. We read online that if we ran the hot water in the sink while taking a shower it would stop erroring. We did that and it worked perfect for about 6 months. A...
lower the output temp on the unit. the tap water could be too cold coming in. The bosche units don't like a large temperature difference between tap water and the water at your shower head. Condensation becomes a real problem. I run my water thru my basement slab to heat it up and that made all the difference, but you probably didn't buy your house with a dirt basement did you?
Dec 08, 2010 | Bosch & Tankless Water Heater
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
Little amount of hot water
Quite likely a bad element. There are two in electric HW heaters. Often the bottom one will fail so you only end up with the upper half heated up.
You can check it with a digital volt meter if you have one.
with the power off at the breaker box, you can remove the wires from the element and (using the ohm (resistance) setting) check across the terminals. it should read around (4500W/240V = 18 ohms).
How old a HW heater? might be time to replace it...
Peace,
Mar 05, 2010 | Water Heaters
Water will not stay hot long enough to shower...not familiar with any of these thermal expansion tanks and can't find any info on vacuum relief valve---40 gal water heater is 18 months old....any...
Turn the gas knob up. There's a dial on the front (probably red) and it will have settings on it. A B and C. Turn up to desired temp, but be careful of faucets if there are children in the house. Good luck
Dec 30, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
436 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
