Question about Panasonic TC-22LT1 22 in. LCD EDTV
TX23 LXD60. Requests a retune each time you switch on
On several occasions when I turn on the set, it says a new channnel has been added and I have to go through the whole tuning procedure which takes 3-4 minutes. I don't believe that many new channels are added and it as though the set is not holding the tuning details once switched off. It's strange though as BBC1 as the first station does show before the option to add new stations appears. Of course I can exit this procedure and all stations are there, so it must be holding some tuning data somewhere. As this is the only freeview box set we have, I have nothing to compare it against. Is this normal?
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
Factory settings on Luxor tv
You should after factory settings ,when you tune the correct channel you must press store ,and if your doing it manual you must press store after each channel is found. That's should do the trick.
Sep 21, 2017 | Luxor Televison & Video
I have a finlux 32 in 3d tv the probi get is wh tv on i am get this no channels have been added yet please go to install and retune menu to add channels i cant even switch tv off with remote
are the remote batteries ok, fit a new set and retry , click on menu go to settings , click on country if asked, click on automatic tuning, make sure there is a good signal at the aerial ,it may take a while , to tune in all the stations.
Nov 12, 2016 | Finlux Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
The tv is fine without the freeview box have tried new scart lead also new tv ariel leadand retunned several times
Are you getting any reception at all? Could it be that the antenna is not receiving the signals??
Jun 11, 2014 | Cameras
Am missing 11 programmes after retuning
Try another aerial. ? Just a suggestion.
Feb 17, 2014 | Luxor Televison & Video
Blocked from facebook
First Change your password ASAP. Request a new password. Its possible that someone has hacked your Facebook Page, and randomly adding people. Also you can turn on notifications for every time your Facebook is Signed into that way you know exactly when it is accessed.
Nov 26, 2013 | Facebook Social Network
Sony KDL-32NX503 I have no channels 1-9 after retuning.
Do a factory reset to this set. Refer its user manual for details.
Apr 22, 2012 | Sony Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
After retune all channnels are not in the right order
Retuned about forty times, not all in the right order but being the telly in the bedroom I'll live with it
Oct 05, 2009 | Televison & Video
Panasonic TC-22LT1 22 in. LCD EDTV Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
