Question about Bagatrix Algebra Solved! 2005 (105101) for PC
X-a=b-a how can you solve it
X-b=0
Posted on Feb 17, 2009
  • 51 Answers
X=b?
Can the scientific calculator solve all maths questions
It depends on your application? I had one on a construction site and it was wonderful. Look up the particular model and see if it applies to you Obiri. Thank you and leave some feedback for I'm a newbie!
Jul 13, 2016 | Scientific Calculator Office Equipment &...
When i ask to solve it wont let me
If it is not accessible (grayed out) then the context is inappropriate. The reason could be the misuse of the verb solve. A lot of people confuse calculate with solve.
If you care to tell us what you were trying to do, exactly, maybe we can help.
Nov 12, 2013 | Texas Instruments TI-Nspire Graphic...
Need instruction how to solve ploynomials/trinomials
You can do it two ways.
Graphically:
Open the graph utility, enter a function y1= expression(x) where expression(x) is the polynomial. Graph the function y1(x). Play with the window dimensions to display the interesting part of the graph. You can then see if there are any zeros (roots).
While the graph is displayed, press SHIFT F5 (G-Solv). Press F1:Root to look for a root. Read the value of the root at the bottom of the screen (to the left).
Solve utility
Open the QEquation solver, select F2:polynomial, or F3: solver.
The polynomial solve can solve polynomial equations up to degree 6.
The solve solve polynomial and any other type of non algebraic equations
Mar 16, 2012 | Casio CFX 9850GA Plus Calculator
How to program the calculator TI-nspire to solve the quadratic formula
Whay would you want to go through the hassle of writing a program to solve to solve a quadratic equation`The calculator has two buit-in command to do just that. It has Solve and cSolve (for complex solutions).
Open a calculator sheet, and on the command line, type in solve(ax^2+bx+c=0, x), press ENTER and wait for the solutions
May 10, 2011 | Texas Instruments TI-Nspire Graphic...
What are the tips of sodoku
Sudoku Tips: Learn How To Solve Sudoku Puzzles Illustrative Sudoku tips teach you how to solve difficult Sudoku puzzles and games. Learn techniques that will make you a pro. Sudoku Tips-Advanced Sudoku Solving Tips These amazing sudoku tips and tricks will show you how to solve sudoku puzzles faster than ever before. Killer Sudoku Tips and Strategies There are three basic methods used to solving killer sudoku puzzles. The first is to use the strategies for solving regular sudoku puzzles.
These sites have some great Sudoku Tips
Mar 18, 2011 | Excalibur Electronic New York Times Sudoku
Solving a linear equation from TI 83
You have two ways to solve an equation (not just linear) in the TI83Plus
  1. The solve( command the syntax of which is solve( expr, var,guess, {lower_limit, upper_limit}). Here expr is the expression (without =0), var is the variable you solve for, guess is you estimate of the solution, lower_limit and upper_limit are the bounds of the domain where you are looking for a solution. Of course your guess must be between theses limits.
  2. The Interactive Solver.
The solve( command
  • The solve command is accessed through the catalog of commands [2nd][0] (CATALOG).
  • Press [LN] (S) to let the cursor jump to the first command that starts with s.
  • Scroll down to reach the solve( command.
  • Select it and press [ENTER]. The command echoes on main screen.
  • Enter the different arguments: expr, var, guess, etc.
  • Close the right parenthesis and press [ENTER].
  • Wait for the solution to be displayed.
The interactive solver
Press [MATH][0:Solver]. You see what is on the first picture (I entered K-0.5*V^2). Press [ENTER]. You see what is on the right picture.
In the interactive solver you enter a value for all the parameters, constants, for all, save the entity you are solving for, here V. So you must clear the 0 to the right of the = sign after the V. when finished you press [ALPHA][ENTER] (SOLVE).
Here is what I get for the small exemple I chose.
Left -rt=0 shows that the root was found to within the calculator's tolerance.
Hope it helps.
Thank you for using FixYa.
Nov 19, 2009 | Texas Instruments TI-30XA Calculator
Solve comlex equation
I do not understand what you mean by solve complex equations, but if you want to manipulate complex numbers here are the tools you need to enter your complex numbers. Operations and function evaluations do not need special symbols.
b4c488c.jpg Hope it helps.
Oct 31, 2008 | Casio FX-9860G Graphic Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
How do i solve for x on my ti-89?
First to solve a problem, write it like this
solve(3/x-2+21/x^2-4=14/x+2,x)
Second, for inverse, do this (note the "y=" part)
solve(y=3x^2 -2x+1,x)
The calculator will rewrite the formula as x = ...
Oct 23, 2007 | Texas Instruments TI-89 Calculator
Open Questions:
Your friend John asks you for advice concerning life insurance. John is 32 years old and graduated from law school last year. he currently earns $48,000 per year as a first year attorney. John is married and has two children, Billy, age 10, and Sarah, age 4. John's wife, Mary, is a professor who currently earns $58,000 per year. Mary is 34 years old. John and Mary pay $1,700 per month for their home mortgage, which will be paid off in 20 years. The interest rate on their mortgage is 4.5%. (Their current equity in the home is $75,000.) The couple owns two cars, both 8 years old, and personal property (such as clothes, electronics, furniture, etc.) values at $45,000. Their investments have been used up paying for John's law school education, so they currently have only $1,000 in savings and checking accounts, and $2,000 in a mutual fund. John has no life insurance. Mary has $100,000 of life insurance provided by her employer. mary's pension plus social security are expected to total $45,000 per year, beginning when she is 67 years old. If John should die, Mary would receive approximately $10,000 per year from social security until Sarah reaches age 18. John and Mary spend most of their current income, although they do try to save about $50 per month. Their investments earn approximately 5% per year. In addition to their home mortgage, John has a student loan of $15,000 that he must start making payments on in 6 months. he plans to pau back the loan in 5 years and the loan's interst rate is 6% per year. Given that Mary enjoys a flexible work schedule, and because Mary's mother lives close by and watches the kids two days per week, the currently are not paying any child care expenses.
Nov 22, 2013 | Bagatrix Algebra Solved! 2005 (105101) for...
Bagatrix Algebra Solved! 2005 (105101) for PC Logo
29 people viewed this question
Top Bagatrix Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Are you a Bagatrix Computer and Internet Expert? Answer questions, earn points and help others
