Question about HP LaserJet 1600 Printer
Paper Jam HP 1600 Laser
I suspect that a sticky transfer has wrapped itself around the heat roller, but I can't get the machine apart, has anybody got a clue as to how I get the top off.
  • odubda1 Feb 18, 2009
    Thanks guys but I need to get into the machine, but cant get the top cover off
  • 1,031 Answers
Go to the link down load the manual go the page on paperjam and clearing
Posted on Feb 17, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 17, 2009
    follow the instructions on the manual to clear the jam.hope this helps pls do let me know
  • 61 Answers
go through this weblink your issue should resolve..
simply open
then search for c00610578
let me know the result..
There is a paper jam in my hp laserjet 3055 printer and I don't know where is the door of this printer to remove the anybody please help me out.
Remove the cartridge from the printer and look for the obstructing paper especially in the arms of the paper detector switches (2 nos. in the path). If you cant see any, the paper has most likely wrapped around the pressure roller / tafflon sleeve in the fuser. Carefully remove the plate just above the cartridge labelled "Caution Hot - Avoid Contact" (after the printer has been in power OFF mode and has cooled down) by removing the two screws on either side. See if the paper has wrapped around the rollers - remove and fit back the plate. In case of repeating problem look for damages to pressure roller and the tefflon sleeve. Have the fuser serviced in that case.
May 28, 2015 | HP LaserJet 3055 All-In-One Printer
I have a Dell 1320c printer and there is a part that I need to replace but I have n idea what it is called. When you open the front it is on the very top. It is the last roller the paper goes through
the last set of rollers are fuser rollers you have a heat roller and a pressure roller the pressure roller is made of rubber and the heat roller is made of aluminium.from the your question im guessing that the paper is wrapped around the heat roller. if this roller has scratches in the serface it does need replacingalso if the pressure roller is damaged it also will cause a papetr jam.
also you should check that all of the picker fingers are all in place and clean.
Feb 12, 2015 | Dell 1320c Laser Printer
Kyocera TASKalfa 3050ci Photocopier paper jam 0100
remove the fuser and look for paper between the induction and roller systems or wrapped around the fuser rollers
Aug 11, 2014 | Kyocera Office Equipment & Supplies
HP P3015N tray two paper pickup issue
Issue is worn out feed rollers. There are three. One in the tray itself and two after you remove the tray. Look up into the printer from where you removed the tray and replace those two rollers
Jan 09, 2013 | HP LaserJet Enterprise P3015d BW laser...
I have a Samsung SCX-4600, great machine but I've got a paper jam and I can't get at it - the troubleshooting guide is very helpful for jams everywhere except in this location - the paper has wrapped...
it sounds like it is wrapped around the fuser roller. is the roller around an inch or 2 around? if so it is the fuser roller and be carefull to no scratch this roller or you will get all jams. the fuser can be taken out with care to look at all the plugs and screws.
Jun 20, 2017 | Samsung SCX 4600 multifunction Laser...
You can attempt to remove the fuser from the machine to have better access to the paper inside. It is very easy to damage the fuser roller and film when removing a piece of paper wrapped around inside.
We recommend calling for service, but worst case is you try yourself and can't get the paper out then you would just order a new fuser.
We can get you the fuser. Just call 262-993-1551. We offer free shipping.
Sep 02, 2010 | HP LaserJet 2420 Printer
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
HP LaserJet 1600 Printer Logo
856 people viewed this question
Ben Johnson
