Question about Technics SCEH790 CD Shelf System
Ipod input for sa-eh760
I would like to hook my ipod strait to my unit?Can I,go in strait thru my mic input from my ipod?do I reuire a DVD?
  • 4,234 Answers
When dealing with audio components there are three different sound levels: Mic, Phono and line. Each requires different amounts of amplification to work properly. Phono levels usually have their own inputs or use external phono pre-amps to get to line level for units that don't have phono inputs. The Ipod can deliver line level which requires less amplification than mic level. If you choose to connect the Ipod to a Mic input, you can possible damage the pre-amp section if the Ipod is turned up too loud. You are better off connecting hte Ipod to any line level input such as the CD or Tape inputs on the back of the unit. You will need a cable that converts from mini stereo to dual RCA connectors. These are common cables that should be available for less than $5.
Good luck.
Dan
Posted on Feb 18, 2009
  • Technics Master
  • 19,396 Answers
You can plug the Ipod into the mic input , to do test recording. But the result wont be great.
To listen the Ipod in your stereo you should plug the Ipod into the Auxiliary input on the stereo.
Naturally you do not need any dvd.
Here is the adapter: 1.5M 3.5mm Male to Male AV Audio RCA Y Adapter
Posted on Feb 17, 2009
Ls-180 x factor karaoke mic
A lot of newer tv you'll have to change the input of the tv to receive the signal. Most should be labeled. If it's red and yellow connectors it will be a composite connection. Some tv companies require a signal to be present before they will switch or even show the different inputs
Apr 22, 2014 | Audio Players & Recorders
I hooked up the Panasonic sa-ht800V Home Theater Audio System SA-HT800V to an old tv the only hook up is the coaxial cable i turned TV to channel 3 and i get picture from the dvd is the a setting a need to...
Look at Page 12 if your TV only has RF coaxial antenna input...
http://www.retrevo.com/support/Panasonic-SA-HT800-Home-Theater-Systems-manual/id/312bh741/t/2/
Add in the Video cable (included) if the TV has an input for it and you'll be able to manage the SA-HT800 through the TV.
Make all the other necessary selections prescribed in the manual.
Jan 23, 2011 | Panasonic sa-ht800V Home Theater Audio...
How do i hook up mt ipod
To hook up your ipod to an a/v reciever you need a stereo mini to male rca cable. You plug the mini side into you ipods head phone jack, and the male rca's left and right(usually red and white colored plugs) to an auxilary input on the a/v reciever.-Example, tape, aux, sa/cd.
Change the input on the reciever to correspond with where you connected the ipod
Ensure the ipod is powered on and playing with the volume turned up.
Jan 04, 2011 | Audio Players & Recorders
HOW CAN I HOOK UP MY IPOD TO MY RECEIVER
Use a phono to RCA stereo jack (pic below) and hook one end to the head phone jack on your ipod and the other ends to your amplifier aux or tape input and adjust the volume to low on the ipod - select the input on the stereo - Aux or tape in.
You'll need this type of cable
Nov 13, 2009 | Technics SA-EX500 Receiver
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
CONNECTING MY TV TO MY STEREO
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
Dec 31, 2008 | Technics SC-DV290 System
Wirering up systeme
I posted a similar solution here:
http://www.fixya.com/support/t1371697-hooking_up_audio_components
- OPTiC
Electronic Repairs & Service
A DJ Pro Audio Co.
Dec 18, 2008 | Audio Players & Recorders
Hooking up an ipod to the stereo
hi
cord from ipod should connect into amplifier input socket.....the headphone on front of most stereos is an output socket....thats like trying to go in thru the out door ...if you get me,
your stereo might not have a separate input.....they are usually on rear of stereo amplifier in older units
Nov 15, 2008 | RCA RS2656 Shelf System
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
May 26, 2008 | Panasonic Home Theater System System
Technics SCEH790 CD Shelf System Logo
719 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
