Question about HP LaserJet CP3505n Printer
Paper feed problem from both tray 1 & 2
When you try print from tray 2 you always get
"13.01.00 JAM IN TRAY 2"
When you pull the tray out to check no paper has made it up in to the printer. Its attempted to pull the top sheet of A4 but its not made it.
If you try and print from tray 1 sometimes it prints but the top left hand corner of the print out is torn and folded over (top right as it comes out of the printer). Sometimes it also jams. The paper can get about 10cm in to the printer and then its pulled to the right and jams.
  • 4 Answers
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Posted on Jun 04, 2009
Why my HP LJ 4100 is always taking envelopes from tray 1, even when I try to print from tray 2?
Check your feed rollers in tray 2. Sounds like they are worn and the paper cannot be pulled from tray 2 so it goes to tray 1
Sep 20, 2013 | HP LaserJet 4050 Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
HP LaserJet CP3505n Printer Logo
573 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
