Question about HP Compaq nc6000 Notebook
Is the primary drive for N6000 a IDE / SATA / PATA ?
I have so many different answers online, I thought I'd aske the experts here!
thanks
  • projector4sa Feb 19, 2009
    nice!, simple and straight to the point answer!
    the other response was real informative too, tho i think answering another post
    :D
  • 1,602 Answers
TAKE OUT THE HARD DRIVE OF THE COMPUTER OR LAPTOP, YOU MAY HAVE TO REMOVE SOME SCREWS FROM THE OUTER PARTION OF THE DRIVE AND LIFT IT UP AND ON THE OTHER SIDE OF DRIVE YOU FIND OUT HOW MANY CYCLINDERS,HEADS AND HOW MANY SERCTORS THE DRIVE HAS AND TURN THE COMPUTER BACK IN GO TO CMOS TO HARD DRIVE SETTTINGS, TAB DOWN TO DRIVE TYPE, SELF SETTING WHEN YOU FIND THAT SETTTINGS THE CYCL HDS SEC WILL TURN TO ZERO 000 FOR EACH ONE AND JUST PUT THOSE NUMBERS IN THE SLOTS ANSWER YEW TO ALL QUESTION F10 SAVE AND EXIT AND REBOOT AND SEE IF THE INFORMATION WILL TAKE, IF IT WORKS THAN TRY TI REBBOT INTO WINDOWS IF IT GOES INTO WINDOWS THAN THE SYSTEM HAD A GLITCH AND EVERYTHING GOS ON NOW IF IT DOES STAY THAN THE CMOS BATTERY NEEDS TO REPLACED WITH A NEW ONE, IT A LITTLE ROUND SILVER TAB LIKE OR A BATTERY PACK YOU CAN BUY AT ANY COMPUTER STORE EVEN RADIO SHACK, BATTERY PACK 3-6VDC, LOOK ON THE MOTHER BOARD LOOK FOR A SPELLING BATT. OR SYMBOLS LITTLE DASH AND BIG DASH, LITTLE HASH AND BIG DASH AND IN THE MIDDLE OF THE DASES ON EACH DASH END ONE BIG ONE AND ONE LITTLE ONE WILL HAVE A MINUS SIGN FACING OUTWARDS THAT IS THE BATTERY SIGN.
THE RED WIRE OR YELLOW, WHITE GOES ON PIN #1
PIN#2 GROUND BLACK, MAYBE BROWN , GREEN.
REBOOT SYSTEM
CMOS, SET CMOS
REBOOT
EVERYTHING SHOULD SETUP AUTOMATIC
AFTER THE SYSTEM RE-INSTALLS ON BOOT UP
ROD IS THE CANDYMANGANDY
Posted on Feb 17, 2009
  • HP Master
  • 32,281 Answers
The NC6000 has an IDE controller, therefore an IDE hard drive. The laptop was configured with 60Gb or 80 Gb hard drive.
Gateway gt4016 motherboard
It has Parallel ATA
PATA or also generally known as IDE,
http://en.wikipedia.org/wiki/Parallel_ATA
1) Harddrive:
101311 - Western Digital, 200-GB, 7200RPM, PATA harddrive,
http://support.gateway.com/s/PC/R/1008842/1008842cl2.shtml
2) Motherboard:
105553 FIC KTBC51G
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtml
Product Views; F - Primary IDE Connector,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr7.shtml
Left side of motherboard, near the black long Ram Memory slots.
This is where the Harddrive plugs in.
Product Views; E - Secondary IDE Connector;
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr6.shtml
Near the black long Ram Memory slots, and next to the blue Primary IDE Connector.
This is Serial ATA, or also known as SATA,
http://en.wikipedia.org/wiki/Serial_ATA
Uses this style of SATA data cable, and connector on motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(NOTE* Color does NOT matter for cable connector.
Color really doesn't matter, for a SATA connector on the motherboard, either.
You are supposed to plug the Primary SATA harddrive, into the SATA 1 connector, on the motherboard.
The beauty of SATA is, that you can plug into any Ol' SATA connector on the motherboard, that you want to.
BIOS will find the harddrive with the Operating System on it, and will find all the other SATA devices plugged into the motherboard, too )
You do NOT have SATA.
Regards,
joecoolvette
[You may be interested in this,
What's Inside: Computer > Computer Hardware > Explore These Categories,
http://computer.howstuffworks.com/
Also to the left;
Computer Peripherals
Computer Security
Computer Software
Internet
And,
http://www.hardwaresecrets.com/
Click on the headings at the top;
Case, (Computer cases), Cooling, CPU, (Processor), Input, Memory, etc.
Has basic information leading up to technical ]
Nov 30, 2012 | Computers & Internet
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
Samsung cd-master 40e will not boot
Is this conected to the motherboard vis sata or (ide)pata?If sata did you put it in the correct port and if so is it enabled.Secondly if ide or pata is the port enabled in the bios or do you have a second device attached to it.If using ide pata one drive should be master or slave ,,, or cable select.
These are the answers why it might not work.The last answer is it died,but i think this is the least likely answer.
good luck
Sep 17, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
Dvd drive replacement
Get a PATA also called IDE drive.They are cheap and will work great in your box.You don't need the speed of SATA for a DVD drive.Even though they make SATA drives. Pata's data tramsission rareis much faster than even the fastest DVD. You have a four device potential for you IDE on your motherboard and only a two device potential for your SATA. Save the second SATA port in case you want to add a second hard drive some day
Nov 28, 2008 | Abit NF8-V Pro Motherboard
Internal HD cabling
I understood your problem there are two different connectors
SATA:
And PATA:
If your computer has IDE (PATA) connectors you need an adapter like this one:
Native SATA Drive to IDE 40-pin Adapter for Most Enclosures
Jul 31, 2008 | Adapters.com Video to Monitor HD-15...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Can i Install PATA hdd on Dimension 4700
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Jan 23, 2008 | Dell Dimension 4700 PC Desktop
Sata vs ide
install the SATA drive in first and install your XP operating system on that one.
Then after thats all set up and running install the PATA drive.
Please let me know how you make out
thanks,
Dec 26, 2007 | Computers & Internet
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
HP Compaq nc6000 Notebook Logo
221 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
