Question about Acer Computers & Internet
No icon showing in My Computer for slave HDD
I've removed my slave HDD, Seagate 400GB Barracuda 720 in old PC (Windows 98) and try to install it on a PC running windows XP. but can't seem to make it work, so i've plugged the HDD back into the old PC. now, the old PC don't recognize the hard drive. BIOS detected it, Device Manager detects it, but it has no drive letter. and My Computer doesn't show an icon for it.
  • 61 Answers
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Posted on Feb 17, 2009
  • morey dumo
    morey dumo Feb 17, 2009
    does your hardrive uses parallel cable or Sata cable? if it is a parallel with correct jumper settings then it should be autodected. if not your hardrive is defective.
MODEL ST3400832A
You must check the harddisk(HDD) connectors and cables unplug and replug them and try to check again
Mar 22, 2013 | Seagate Barracuda 400GB 7200 RPM SATA 3.5...
I have a seagate barracuda 7200.12, 500 GB, HDD, as suddenly it is not working nothing is showing up, some type of clicking sound is also coming from it. the computer detects the hdd, but nothing is...
If you have another computer, you could try to plug it in there as a slave/secondary drive so that you can try to see if My Computer would still recognize it. If it works, then great, you can still do backups. If not, and you really need that data, you might want to get the services of a data recovery company.
Jul 29, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Computer doesnt pick up a usb
Remove the HDD from the enclosure and slave it inside your PC...if it reads it will be the enclosure is faulty. If still no read is faulty HDD.
Oct 16, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Windows
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Dec 16, 2007 | Seagate Barracuda 7200.9 ST3400833AS 400GB...
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
180 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
