Question about Microsoft Visual Basic Professional Edition 6.0 for PC
Write into excel format
Ive made an apllication that write my database into ms access.btw im using vb6 and ms access.below are my code that write db into ms access.but i want to change that into ms excel format.can anyone help please
code :-
Private Sub Command1_Click() BkpUpFileName = "" + Me.txtBkUpDest.Text + "\" + Me.txtBkpUpFName.Text + ".xls" Set FSO = CreateObject("Scripting.FileSystemObject") FSO.copyfile App.Path & "\Library.mdb", BkpUpFileName Me.Drive1.SetFocus ProgressBar1.Visible = True Timer1.Enabled = True
End Sub
  • steve260 Feb 18, 2009
    i just copy that code from other project...;)
    do u mind sharing vb code that access db adn write into csv file, please...
    mind if u share some code or website so that i can write into excel file??
  • 68 Answers
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Posted on Feb 17, 2009
Repair MS Access database without having program installed
Use Recovery Toolbox for Access developed for recovering data from corrupted Microsoft Access databases. The MS Access recovery tool is capable of repairing MDB and ACCDB database files.
For more: https://access.recoverytoolbox.com/
Oct 18, 2015 | Microsoft Office Computers & Internet
Different between MS EXCEL & ACCESS
Hi. MS Excel is for spreadsheet. Very useful when creating accounting documents. MS Access is for database. Very useful when collecting data.
Please visit these links to learn more about the 2 applications:
http://www.blurtit.com/q373300.html
http://office.microsoft.com/en-us/access-help/using-access-or-excel-to-manage-your-data-HA001042918.aspx
http://www.thetechfaq.com/2010/03/14/microsoftaccess-and-excel-comparison/
Sep 03, 2010 | Microsoft Windows XP Media Center Edition...
How can i repair a damaged access database
There are some reasons which may damage your MS access database such as virus infection, software crash, accidental shutdown of system, unrecognized format of database, corruption of storage media etc. These issues are easy to overcome by using third party software of access database repair.you can try Kernel Access Database Recovery Software one of the best software in Data Recovery
For information you can visit here ...http://www.accessrecoverytool.net
Aug 23, 2010 | Microsoft Computers & Internet
Getting "Unspecified Error" While Opening an Excel File by using OLEDB Connection. I am Using Follwing Code to Open the Excel File. string connectionString = @"Provider=Microsoft.Jet.OLEDB.4.0;Data...
Hello, you are probably using an incorrect connection string.
Usually you can use a datasource (such as Access Database) directly in an excel document. If that is what you are trying to accomplish here check out the following sites:
Plug into your data Connecting Excel to an Access database Office Blogs
OR:
Connect an Access database to your workbook
If you are writing software application, from within Visual Studio (depending on the version) go to the left-hand side bar to "Server Explorer" -> "Add Data Connection" -> Click on the "Change" button of the Data Source part and select the appropriate Access Data Source -> Click the "Advanced" button.
After that, you will see in the bottom textbox, the appropriate connection string for the JET.OLEDB Connection Provider.
This is shown in the image below:
fews-khtxegu4lrzhmquqt25la0x1-4-0.png Alternatively, you can find more information about your connectivity string in the link below:
https://www.connectionstrings.com/microsoft-jet-ole-db-4-0
For usage of an oledb connection object you can find info here --> https://msdn.microsoft.com/en-us/library/system.data.oledb.oledbconnection(v=vs.110).aspx
Mar 30, 2017 | Microsoft Computers & Internet
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
You can use ADO or SQL to open the excel file directly (provided it is constructed correctly, ie fields names) and write the data to it without Access.
That might be eaiser thatn converting it from Access to Excel, if that can even be done.
Feb 17, 2009 | Microsoft Visual Basic 6.0 for PC
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
Database synchronizer
You can see this website it will help full for your project. If you need any help means you can ask me..
http://www.academictutorials.com/
Feb 25, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Coding in ms word by using visual basic editor
Hello Kavita! If you want to get the most of VB then i advice that you install Microsoft visual studio...But just in case you want it for free you can find it here..
http://www.brothersoft.com/downloads/vb6.html
Nov 10, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
Microsoft Visual Basic Professional Edition 6.0 for PC Logo
199 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
