Question about Bowflex Selecttech 1090 Dumbbells
Bowflex 1090 selectech fault
I have a bowfex 1090 selectech, only 4 months old. I have found that the large weight nearest to the handle drops out when shaken. Sometime it just falls out. Ive noticed that there tends to be more movement between the handle and the first weight. Obviously a manufacturing fault and maybe many others are having the same problem. I live in a remote area hence unable to use manufacturers garantee. I just want to know how I can fix it!!
  • moody608 Feb 17, 2009
    I'm having the same issue. Took a look at mine and you'll see fins that hold the weights in place. I'm guessing that yours is cracked like mine. This crack allows the tab that holds the weight in place to slide away from the weight causing the weight to drop out. I spoke with bowflex yesterday and they told me to try removing the logo end caps and tighten the bolts there, but in the process I found the problem I described earlier. If you are going to try tightening the bolt, make sure that you remove both endcaps and tighten both sides as they are connected and will just spin if you don't.
  • Anonymous Mar 29, 2014
    The cable end that goes into the weights falls about a foot short with weights flat to the floor. Cable will not reach plug in first weight that cable end screws into. All the cable routing seems correct on system. Others have posted same problem but I cannot find an answer.
If you have an issue with the SelectTech dumbbells of any kind, just contact the customer service phone number 1-800- BOWFLEX. All they require is a proof of purchase (receipt) to be sent in and they will send you any replacement parts free of charge. You do not need to send the old parts back first.
Posted on May 29, 2009
The problem is that the composite disc or "circle" on the handle that holds the weight is cracked or damaged, thus allowing more play for the disc to move and by pass the teet on the weight itself.
I own these also, and I should have done some more research before purchasing them. I believe that a new handle (which is what bowflex will sell you) will exceed $100.
These things are not suited for the higher weights.
Both of my handles are screwed. I will be getting a set of Iron Masters in the future rather than repair these.
I hope this helps
Ray
Posted on Apr 19, 2009
  • ask222 Mar 01, 2011
    I agree. The weights are not suited for the higher weights.
    The parts are cheaply made. The pin mechanism is cheap plastic. Not strong enough to withstand higher weights.
    I do no recommend these. The handles mess up and are rediculously priced to replace.
  • pone00 Jul 27, 2013
    I bought a pair of 1090's brandnew from bowlflex which are priced on the high end. Infact they are expensive. Expensive because they are supposed to be well made to last years without the problems I have experienced and read about. Thanks to you and everyone who contributed the knowledge on Fixya. Thumbs Up!! Thanks!! Great Help!!!!
Selector knob spins, no clicks, does not select the weights. The metal disk near the handle does not move.
1. Check to assure that the ******** handle is fully depressed into the ******** base. If not fully depressed, the locking mechanism will not be released and may be keeping the adjustment knobs from rotating. 2. Check to see if any weight plates have been put into the base assembly backwards with the "support ******" facing the grip of the ******** handle. All weight plates must have the selection ****** facing away from the grip of the ******** handle. 3. Check to see if there is any dirt, debris or other obstruction in the ******** base. You may need to remove the weight plates from the base to accomplish this check. Remember to put each weight plate back in its appropriate location with the selection ****** facing away from the ******** grip.
Aug 15, 2011 | Bowflex Selecttech Dumbbells
Once the dumbell is on the base the dial will not spin so you can not pick up any weights. I can push the putton on the bottom when I am holding the unit with out any wieghts and the dial will spin but...
Try setting the handle in the plates back onto the carrier(bottom). Lightly tap on each plate that is stuck. Now push the plates down (vertically) onto the bottom carrier. Now try turning the dial (side that was stuck). It worked for me. Have my 1090 plates were stuck on the handle. Good luck
Jun 11, 2011 | Bowflex Selecttech Dumbbells
Bowflex Select Tech will not come out of base. Is there a lock or some mechanism that won't allow leaving base?
One of the weights is most likely a little off in the base. To unstick, remove the four screws on the base, then the two screws on clip. Handle will then remove.
Dec 25, 2010 | Bowflex Selecttech Dumbbells
My bowflex dumbells are jammed and i cant remove them from the holder
Hi I called 1-800-628-8458 (the number in the manual) after trying several of the methods shown here. None worked. your dumbbell needs to be on a flat surface, no roll the dumbbell over to where the weight is facing the floor and the base is up in the air. With both hands lift the base and gently shake, the weight should fall out. Put the base back on the floor face up and inspect the grooves where the weight plates go for any debris. Clean this area if you find debris. Now you will need a pen or pencil with your weight. Grab your weight, still facing down and you will see a black release button on both sides on the inside of the weight. It is in between the metal dial and the inner part of the weight. Now press down on that button with your pen or pencil and start turning the dial (caution: the weight plates are going to fall out) keep turning until all of the plates are out. Do the same thing for the other side. Now grab each plate and put it back on the base where it goes, the smallest plate on the outside to the largest plate on the inside, make sure the small metal piece on the bottom of each plate is facing away from the inside of the base. Do this for all of the plates. Now back to the dumbbell. Grab your pen or pencil again and press down on the black release button and turn the dial to where the number 5 or lowest weight is selected where it reads Bowflex. Do this for both sides. Now grab your dumbbell and carefully put it back into the base. It is important that you put the dumbbell down straight, avoiding any shifting in plates.
I hope this helped.
Dec 21, 2010 | Bowflex Selecttech 1090 Dumbbells
Weight Plate falling off
Thank you! I found the reset button and now it works again.
Jul 16, 2010 | Bowflex Selecttech 1090 Dumbbells
Selecttech 1090 Dumbbells: the end caps that adjust the weight are stfrozen, ...
Just call Bowflex. If you don't want to call here's the solution. There is a reset button on the bottom of the handle. Take the handle out, place on the floor side ways, depress the square button and turn to 5 lbs. Whatever weights that were on handle will fall out. Place the weights back into the holder. Make sure they are positioned correctly then put the handle back. Then test by dialing up different weight settings and lifting the ******** out of the holder. You should be back in business. If that doesn't work call Bowflex which you should do anyway.
May 18, 2010 | Bowflex Selecttech 1090 Dumbbells
One of my Bowflex Dumbell's dial will not turn,
Hi there, I wanted to add my solution to these as I bought a set of second hand bowflex dumbbells only to find one of them wouldn't turn. The dail kept sticking or just not turning. After hitting goggle and coming up blank i turned to the tool box lol I set the bar to 5lb both sides and removed the handle, leaving all the weights in the base, I then removed the weights from the base one by one. Once the base was empty I replaced the empty handle onto the empty base and tried to turn the knob, it wouldnt turn, on the base there are two metal hooks, these stop you pulling the handles out In between weight settings, the metal hook on the base was hitting the metal disk (which has many hooks all around it) on the handle. I lifted the handle off Swaped sides and it still was hitting the metal base hook. If you undo the 6 screws on the underside of the base and pull apart the two halfs you will find a large black square which is held in place by 2 more screws, remove these and pull out this square, you will now have access to the underside of those two metal hook (which are held in place by two screws each) undo these a little and push back on the hooks and retighten these screws, turn the base over and replace the handle to see if the dial will turn freely on the base. Replace all the screws, re fix the two base halfs together, sit the weights down in the base, place the handle back and turn that dail Hope this helps someone.
Apr 01, 2010 | Bowflex Selecttech Dumbbells
Have boweflex selecttech dumbbells and one set will not turn dial and change weights please contact me at worldcitizented@yahoo.com and advise me how to get this repaired thank you
Either the handle is broke or try making sure all the weights are facing right way (same way) or the handle will not sit all the way down. It needs to sit all the way down for the button on the bottom of the handle to be pushed to release the adjuster to be able to spin and grab weights.
Feb 22, 2010 | Bowflex Selecttech Dumbbells
One of the weight disks slipped and will not lock how to make it lock again
place the weights back on the stand and make sure that all the weight plates are facing outward. you can verify this by looking at the bottom of the disks there are small little square protruding out make sure they face away from the handle. if they dont lock into place after this then someone in the valves must be broken. good luck!
Oct 31, 2009 | Bowflex Selecttech Dumbbells
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Oct 21, 2008 | Bowflex Revolution Home Gym
Bowflex Selecttech 1090 Dumbbells Logo
3,432 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
