Question about Onkyo TX-SR506 Receiver
Buzzing/vibration noise - ONYKO TX-SR506 amplifier
I have recently purchased a ONYKO TX-SR506 amplifier. All speakers are connected but when I switch on the actual unit itself it emits a buzzing/vibrating sound. We have tried moving it but is is still there.
When volume is turned up is covers up the noise but it is still there and is annoying.
  • Anonymous Mar 02, 2009
    I have the same problem. Right now I don't have my rears set up so I'm currently set up with a 3.1 config (3 in front and a sub). As soon as I turn on the unit I get a loud buzzing sound. I thought it was a fan at first, but it doesn't seem that way.
  • Anonymous Apr 06, 2009
    I have the problem as well, the weird part being that it definitely wasn't there a few weeks ago. The hum (if it sounds like mine) is a problem called an earth/ground loop, where the receiver ground and the grounding on whatever you've got plugged into it as an input source are different grounds, so different that they are producing a current (i.e. that "humming noise"). Here are a few things normally done to fix this:
    1. Plug the receiver into the same power-strip as whatever input device you're using is plugged into. So if you're using a PS3 plugged into a power-strip, plug the receiver into the same power-strip.
    2. Check to make sure the power-strip itself is grounded. The grounding pin on a plug is the long round pin, the bottom pin of the 3. If your power-strip doesn't have one then your strip is very old and it's time to upgrade. No worries, they're cheap.
    I'm still here with the humming noise because neither of those two worked for me. Granted, earth/ground loops are very tricky things, and what didn't work on my TX-SR506 may work on yours.
3 Suggested Answers
  • 4234 Answers
SOURCE: Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
Posted on Feb 17, 2009
  • 333 Answers
    Verified Fixya Pro
    The issue is that when you hook up the HDMI connector (Only) from a source into the receiver the subwoofer will produce a audio hum if the source is either not playing or in a pause state you will hear the hum. Once you remove the HDMI connection the humming disappears. Again the UPDATE will reduce it 90% but at a high volume you can still hear the hum come out of the subwoofer and you know that if the customer knows about it they are going to be looking for it after the update. So at this point after the UPDATE you will hear some hum because the receiver is still processing a signal through the system. But at normal listening it's not going to be producing any humming, just your normal bass signal is going to be produced.
    Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at parts@us.onkyo.com. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding warranty and service issues. You will need to speak with the Parts & Services/ Warranty department for any servicing options or resolutions available for your issue.
    Posted on Apr 17, 2015
    My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
    How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
    Feb 06, 2013 | Onkyo TX-SR506 Receiver
    I have a Onyko TX-SR303 5.1 Receiver and sound is only coming out of left front speaker.
    Could be the IC that controls the various sound/surround channel modes. Had that happen on my Pioneer receiver.
    Charged me close to 200 bucks to fix!
    Aug 24, 2017 | Onkyo TX-SR303 Receiver
    Should i use an amplifier with the txsr506. i dont know if im doing anything right with the receiver. i feel like its two low on volume
    It HAS amplifiers. You don't daisy-chain amps.
    Get the manual and take some of the gueswork out of the process. Set it up and come back with specific questions.
    Register and download the manual for free at retrevo.com
    http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/
    Jul 05, 2011 | Onkyo TX-SR506 Receiver
    I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
    Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
    Mar 15, 2010 | Onkyo TX-SR506 Receiver
    Alot of loud feedback through speakers, a loud buzzing noise
    What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
    One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
    Apr 10, 2009 | Onkyo TX-SR606 Receiver
    Keep us posted.
    Dan
    Feb 17, 2009 | Onkyo TX-SR506 Receiver
    Muffled sound from rear speakers why watching TV
    switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
    Feb 12, 2009 | Onkyo TX-SR506 Receiver
    Blow right speaker channel - ONKYO TX-SR506
    There is some way to change a protection (fuse?). No. The fuse usually was not broken. How long did your amp turn on?
    3 seconds (DC protect) OR immediately shut down (Over Current protect)? How to confirm?
    1.Unplug the amp.
    2.Remove the metal cover.
    3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
    4.Remove this long vertically installed board mounted by 2 screws.
    5.With 2 screws removed, just pulling this board out and hold it with one hand.
    6.Plug the amp and switch it on.
    7.If your amp stays ON forever, the problem is from this long board.
    8.If switch off at once, the problem is from power amp board.
    Try the above- mentioned steps. I will tell you what to do next. Just search you tube for SR600 cap replacement. I have written an email here. Write an email to me if you want to fix this amp.
    Sep 30, 2017 | Onkyo HT-SR800 System
    Distortion/noise and buzz in front left speaker
    Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
    Dec 28, 2007 | Onkyo TX-SR503 Receiver
    Onkyo TX-SR506 Receiver Logo
    348 people viewed this question
    Top Onkyo Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
