Question about Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI
Connect cd drive to biostar gf7100p-m7s
I bought a biostar gf7100-m7s and i cant figure out how to plug in my cd drive it has a 34 pin cable but my drive has a 40 pin. do i need a special ribbon cable?
  • 32 more comments
  • bloodaxe6666 Feb 17, 2009
    but there is only 1 40 pin conector for the hard drives what do i connect the cd drives to?
    only one
    can i just connect the cd drive with the same cabel i conected the hard drive with?
    how do i do that
    no is it that little plastic clip in tha back
    lg gsa-h55l
    hard drive is sea gate barracuda 7200.7
    the cd drive is the slave. the lg drive dosent have the words slave or master. do i put the clip in the middle
    then what do i doo
    yes i will connect hem now
    what is the sata cabel for?
    it has xp on it . what is this sata cabel for?
    oh i dont have one of those do i?
    i dont have the memory in yet its coming tomorow. how do i connect the power supply to the board. there is only a small 4 pin conector that will fit and i have all these extra cabels haning is that ok?
    how do i do a windows repair?
    do i connect thhe power unit to the jcfani slot on the mother board?
    i have it hooked up to the slot by the memory slots top right section of this diagram
    is it marked jusbv2
    oh yes thats where i have it. so thats it for the power connections?
    what is the slot marked atx power conector in the diagram for none of the cabels comming from my power supply fit into it
    do you meen the 24 pin connector?
    ok so i need a new power supply to fit that atx connection. do you have any suggestions? its is a antec design cace
    so i need a new power supply? do you have any suggestions which one i need?
    man you are awsome yo saved me some time and money for sure
    is there anything i need to know about the cd rom audio in connector?
    i have a creative sound card do i plug it in there?
How can i get digital audio?; for example, how can i capture the Modem´s Dial - Up sound in order to save it at any particular audio format?
Posted on Feb 17, 2009
  • vectorresear Feb 17, 2009
    How can i merely identify all of the crucial wired buses at any laser Pick - Up in order to generate a replacement for use it in any type of electronic CD-ROM or, even an audio equipment whatever it can be; say Car audio, Discman, etc?
  • 837 Answers
The 34 pin connector is for your floppy drive(s) .. not for your CD drive. There is no special cable for this. 2 different interfaces alltogether.
  • 21 more comments
  • Jay Glendenning
    Jay Glendenning Feb 17, 2009
    Are you using 2 IDE hard drives on that IDE cable?
  • Jay Glendenning
    Then you can connect the cd drive. Set the jumpers on your hard drive to master and the CD drive to slave.
  • Jay Glendenning
    Then route the IDE cable accordingly to the IDE HD drive and the CD drive
  • Jay Glendenning
    Do you know how to set the jumpers and/or know where they are?
  • Jay Glendenning
    What kind of hard drive (make/model) do you have?
    What kind of cd drive (make/model) do you have?
  • Jay Glendenning
    Ok the back of the CD drive will look similar to this
    But you will put the jumper on the middle set where it says SLAVE
  • Jay Glendenning
    For the hard drive it looks like this
    You need to set the jumper on 7&8 as shown for master or single drive (top option)
  • Jay Glendenning
    Yes put it in the middle since it is not labeled
  • Jay Glendenning
    Have you set the jumpers for the CD drive and the hard drive as I have shown/discussed?
    If so you then need to connect power leads and the IDE cable to both devices
  • Jay Glendenning
    You should be basically ready to "run". I am assuming that you have already installed the CPU and the RAM.
    I generally like to "bench" connect now. Don't close up the case. Connect the power cord, keyboard, mouse and monitor cables to the computer. Turn it on and be sure it is booting.
    Is the hard drive new or does it have Windows or some other operating system already on it?
  • Jay Glendenning
    The SATA cable is for SATA hard drives, cd rom/dvd rom drives, etc.
  • Jay Glendenning
    You may run into some issues with XP and this new motherboard, that may require a windows REPAIR installation.
  • Jay Glendenning
    No .. your devices are all IDE
  • Jay Glendenning
    Your board should look like this
    You need to connect on the ATX power connector and sorry but the 4 pin power connector goes in the connector that is in the connector that is near the inside corner of the arrow that points to the Nvidia Gforce chipset
  • Jay Glendenning
    This an excerpt from a microsoft page .. here is the link if you want it
    http://support.microsoft.com/kb/315341
    Repair install of Windows XP by starting your computer from the Windows XP CD
    loadTOCNode(3, 'moreinformation');
    Note
    If Windows XP was preinstalled on your computer, you may need the
    installation CD to reinstall. Contact your computer manufacturer to
    make sure that you have the installation CD for a repair installation.
    To reinstall Windows XP by starting your computer from the Windows XP CD, follow these steps:
    1. Insert the Windows XP CD into your computer's CD drive or DVD drive, and then restart your computer.
    2. When
      you receive the "Press any key to boot from CD" message on the screen,
      press a key to start your computer from the Windows XP CD.
    3. The following message on the Welcome to Setup screen will appear: This portion of the Setup program prepares Microsoft Windows XP to run on your computer:
      To setup Windows XP now, press ENTER.
      To repair a Windows XP installation by using Recovery Console, press R.
      To quit Setup without installing Windows XP, press F3.
    4. Press ENTER to set up Windows XP.
    5. On the Windows XP Licensing Agreement screen, press F8 to agree to the license agreement.
    6. Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
    7. Follow
      the instructions that appear on the screen to reinstall Windows XP.
      After you repair Windows XP, you may have to reactivate your copy of
      Windows XP.
      For more information, click the following article number to view the
      article in the Microsoft Knowledge Base:
      310064
      http://support.microsoft.com/kb/310064/
      How to troubleshoot Windows XP Setup problems when you upgrade from Windows 98 or Windows Millennium Edition
  • Jay Glendenning
    Yes .. that is the proper connection for the power supply to the motherboard
  • Jay Glendenning
    What kind of case/computer is this motherboard being put in? That ATX power connector MUST BE USED .. If you do not have a power connector coming from your power supply that fits that connector .. you cannot use this motherboard and/or case/power supply.
  • Jay Glendenning
    If you look at page 15 in the user manual .. that must be followed for power connections
  • Jay Glendenning
    Yes thatJ ATXPWR1: ATX Power Source Connector and the 4 pin JATXPWR2: ATX Power Source Connector
  • Jay Glendenning
    This would work fine
    http://www.geeks.com/details.asp?invtid=...
  • Jay Glendenning
    Glad to help .. And thanks for the FixYa rating .. Don't hesitate to use us again ..
  • Jay Glendenning
    If you have that audio cable you can connect it to the cdrom and motherboard. The audio cable just connects the line level audio output form
    the CD-ROM drive to one PC sound card (onboard) line level audio input dedicated
    to CD-ROM audio cable.
  • Jay Glendenning
    Yes .. use the sound cards connector then .. and be sure to disable the HD Audio in the BIOS setup under Integrated peripherals
When try to make the M/B on it just run the cpu fan and power drops instantly ?
That means the PSU( Power Supply Unit ) is not giving enough power.
Check the wattage of your PSU, it should be 500 watts or more to power up that MoBo or the PSU your using is not working anymore.
Hope that helps you out!
Sep 13, 2011 | Biostar GF7100P-M7S Motherboard - v6.0,...
My motherboard Biostar GF7100P need to program bios ,\r\nmy motherboard only turn on but do not action ( no picture in screen , no beep in motherboard ) my pci post code card show "FF" code in...
The first thing that I would do is check the MoBo's website and find a RAM compatibilty chart. Make sure that you Mobo doesnt have any know issues with your particular RAM. You may also check the RAM's website and look for compatible RAM for your MOBO. Rule this out first. The Sata F6 thing depends on the MOBO I think that most of the time you do have to f6 the drivers however on my ASUS this was not necsessay. My cut at this would be to take everything out of your system except for the few components that it requires to boot up and load the OS. RAM, Video Card, CD ROM, maybe the Floppy. Reformat your HD so that you can start over clean. Make sure that you have each cable plugged into the mobo correctly as well as the component. Reformat, then reload the OS. Start to load the system drivers one at the time rebooting after each is loaded. Pay attention to what you did last if the problem shows up again. This will probably point you to the issue. If every thing installs correctly without any problems then start putting the other hardware in one piece at the time loading the drivers andsoftware for each component then rebooting and ruung some stress test before moving to the next component.
Jan 19, 2011 | Biostar GF7100P-M7S Motherboard - v6.0,...
Biostar gf7100p-m7s hard drive not working
I would flash the BIOS, sounds like something is corrupted, if that doesn't work then the blame has to be the HDD, you need to try booting with a different one, maybe a PATA too see if your problem goes away or changes. Any PATA will do, this is only a test.
http://www.biostar.com.tw/app/en-us/mb/bios.php?S_ID=348
Another SATA would even be better. Good luck.
Jul 15, 2009 | Computers & Internet
Biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Jul 07, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Sound doesn't work on biostar gf7100p-m7s
it's a common problem of gf7100p-m7s series. Its depend on ur operating system. beoz many operating systems have their own audio drivers like windows vista. If u r using windows vista don't install audio drivers from ur motherboard disk. becoz i had faced this problem some months ago. if this is not hardware relative problem, u can see ur sound will work fine.
May 28, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
On first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Need correct hard drive for Biostar GF7100P-M7S
This isn't even a question plus its a silly post overall. SATA is a proven technology that is much faster and just as stable as UDMA.
Jan 03, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Biostar GF7100P-M7S Motherboard - v6.0, NVIDIA GeForce 7100, Socket 775, MicroATX, Audio, Video, DVI Logo
735 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
